Yolandi Posted June 19, 2016 Share Posted June 19, 2016 Hi all, in the wet british summertime i thought id try and fix up my rear door, the demister is on track with some element repair compound stuff on its way and the relay for it re wired and now my attention has turned to the wiper, its had a replacement door that doesnt have any electrics or motor in it, up front i have the rear wash wipe switch fitted and as far as im aware it does work and behind the corner cover in the back there is the round 3 wire connector for the wiper motor, anyway my question is do i need to get the door look that includes a relay in it or the type without? and because i always forget to mention its an 1991 defender 110 Thanks! Quote Link to comment Share on other sites More sharing options...
Yolandi Posted June 19, 2016 Author Share Posted June 19, 2016 "Door loom" sorry typo Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2016 Share Posted June 19, 2016 No relay on rear wiper system, Yes you need the loom for the door/wiper motor, Autosparks http://www.autosparks.co.uk/ do this one that will connect to your other loom connector REAR DOOR HARNESS - 90/110PART NO:LR479FINISH:PVC Cables with a Taped Outer CoveringCHASSIS NO:270227 - on Defender 90/110 Rear Door Harness with HRW and Wash/Wipe. Washer Bottle in Engine Bay. PRC 6290 Quote Link to comment Share on other sites More sharing options...
Yolandi Posted June 19, 2016 Author Share Posted June 19, 2016 Cheers western ? Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2016 Share Posted June 19, 2016 this how I replaced my rear wiper motor with the later 300tdi onwards type, the early motor is no longer availabe. http://forums.lr4x4.com/index.php?showtopic=96820&hl= Quote Link to comment Share on other sites More sharing options...
