ronnie_rotten Posted June 29, 2016 Share Posted June 29, 2016 Is it possible to essentially blank off and remove the oil cooler from a td5? Can blanking bolts or similar be used to remove a leaking cooler rad from inside the housing until a new one is sourced? What are the likely consequences in UK climate, is the oil cooler absolutely critical to the engine? Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted June 29, 2016 Share Posted June 29, 2016 You'll be fine in a UK climate. In fact Id say you'd be fine in most climates! Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted June 29, 2016 Author Share Posted June 29, 2016 You'll be fine in a UK climate. In fact Id say you'd be fine in most climates! Good stuff. I really just want to get the thing so I can move it without filling the cooling system with oil! I don't suppose you happen to know what bolt/seal sizes I'll need to blank the outlet? Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted June 29, 2016 Author Share Posted June 29, 2016 Can I just swap the banjo bolts for normal ones as a temporary fix until move it to the garage and take it apart properly? Quote Link to comment Share on other sites More sharing options...
