stephencdavies Posted August 23, 2016 Share Posted August 23, 2016 If i drive around without having to change gear too often my gears are fine. if i get stuck in traffic several times on a long journey, the gear sometimes are a pain to engage. this is normally only 1st and reverse from a stand still. any ideas whats causing this. its a new clutch system , new slave and master, with new fluid. i do tend to hold it on the clutch a bit, especially on the hills. 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 23, 2016 Share Posted August 23, 2016 The last sentence. Mo 1 Quote Link to comment Share on other sites More sharing options...
Tal Posted August 23, 2016 Share Posted August 23, 2016 definitely sounds like clutch hydraulics to me... most likely is an air bubble. bleed it through with a long clear pipe on the lower bleed point (long bit with a high bend then into a clean bottle to save fluid) and see if you get air coming through...if you do, keep going till you don't have any more....but remember to top it up every so often or you'll just pull more air into the system Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted August 23, 2016 Author Share Posted August 23, 2016 Thanks guys. i'll get the thing bled then, oh, and stop riding then clutch........... Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 24, 2016 Share Posted August 24, 2016 Bleed the clutch with the vehicle parked pointing uphill (or jacked up, remembering safety pints like chocks and axle stands) to make sure that any air in the slave cylinder is forced to the bleed nipple - it's impossible to get a 100% bleed with the vehicle level or pointing down. 1 Quote Link to comment Share on other sites More sharing options...
