Help - Search - Members - Calendar
Full Version: LT77 gearbox extension-cases swap
LR4x4 - The Land Rover Forum > The Lounge > International Forum
RoLandRover
Hi folks,
I've got a 'minor' problem with my gearbox, just when I could drive my first meters with the car
It doesn't stay in reverse!
I need a Longstick box to suit my RR, and I have plenty of LT's of variing types laying around which should work fine.
so I'd like to know, can i swap the case-extension of the longstickbox with i.e. the later shortstickbox versions?
or even better with an R380?
hope to hear!
Grtzz,
Rolandrover
<b>RAN OVER PROJECT.Update 25 Oktober.</b>
<a href="http://www.mijnalbum.nl/Album=TLQCICKI"target="_blank"><img src="http://www.mijnalbum.nl/MiniFoto=LVXQTBFV" alt="RanOver 3.5V8 '73"></a>
LOVE,PEACE'N'AXLEGREASE.
fotosite http://www.mijnalbum.nl/Album=TLQCICKI
Henry Webster
In typical LR style, I think the answer is yes and no. Some LT77s can be swapped and others can't!
Unfortunately I don't know the details of which are compatible with which. I do know that there are some fundamental differences between earlier LT77s and late ones.
Hopefully someone with more specific knowledge will be along soon! However if you've got some lying about then I would suggest some trial and error. I bought a few gearboxes with this swap in mind (actually the other way round) and found two of them to be incompatible.
H
ashtrans
QUOTE (RoLandRover @ Dec 13 2006, 06:00 PM) *
Hi folks,
hope to hear!
Grtzz,
Rolandrover
Henry's right, some you can, some you can't,
please advise the serial numbers of the boxes you have and what you want to end up with and I will let you know what you can use,
RoLandRover
Thanx Dave,
appreciate it, will do an inventory.
grtz,
Roland
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
