QUOTE (nicksmelly @ Dec 18 2006, 10:48 PM)
I'm looking for some cheap Peli type waterproof boxes to put some / a camcorder/s and batteries in a comp safari racer. Dimensions of about 12"x10"x6" or there ish. Needs to be strong enough to survive ratchet strapping in place.
Anyone any ideas or source of cheap pelican or storm boxes?
Nick... the smelly one
Not quite that big, but how about an H83 ammo box? - if you could squeeze it in there you'd have a totally waterproof (as long as you proof the holes that you make for wires...) and very tough container for less than £10
Anchor Supplies say this:
Bolted to the floor they make great safes... ideal to keep your valuables safe and secure.
Details:
External dimensions: 300 x 155 x 185 mm (approx 12" x 6" x 7.5")
Internal dimensions: 280 x 140 x 175 mm ( approx 11.5" x 5.5" x 7")
Weight : 3kg
Construction: Fully welded seam Galvanized Steel
Finish: Brown Gloss or Olive Green
Fitted Rubber seal on inner lid which is compressed to seal the box when shut
Lie Flat handle permits easy carrying.
VERY Rugged and Durable... Should last a Lifetime
Rog
