Help - Search - Members - Calendar
Full Version: Engine stand and 200Tdi
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
nige90
Hi alll,
Picked up an engine stand from our favourite market place and would like
some advice on where to fit the Tdi onto it. Side or back where the flywheel
housing fits ?
It's a Machine mart job, which according to the website can handle 340kg
but I've already removed a lot of weight, head and ancillaries. All I intend
to hang off the stand is the basic short motor to facilitate sump removal.
Thanks in advance.
Nige
BTW what is the weight of a built up 200Tdi anyway ?
Les Henson
I didn't know and engine could be mounted on a stand from the side. You could build the whole engine without problems in that case.
340kg is more than 1/4 ton, so should be strong enough.
miketomcat
QUOTE (nige90 @ Dec 21 2006, 12:06 AM) *
Hi alll,
housing fits ?
Thanks in advance.
Nige
i'm building a 200tdi on said stand at the mo ive bolted it on the rear face of the block with clutch and clutch casing removed using the four cap head bolts from the clutch casing was then going to hang it on the crane to do the clutch end and then bung it back in the truck BTW its a defender lump but i don't think it makes much differance
mike
diesel_jim
Here's how i recently did a 300Tdi, my engine mount has adjustable arms so i just hung the engine there with the crane and adjusted the arms to suit:
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
