QUOTE (pritch1 @ Jan 9 2007, 06:07 PM)
Would be nice to see a 90 running something like 38.5 boggers with almost 90 degree depature and approach angles (pushing the front axle forward) and without being lifted to stupid heights. When i get the money i would love to do it. weather i start again with a 100 inch or mod the 90.
I built an awdc class one trialler with a nearly 90 degree approach angle on 7.50's (i know its not a road vehicle, but someone cleverer than me could improve my idea).
I just used parts i had lying round the place, nothing major.
the set up went:
Home made column of golf steering uj's, directly onto a rangie PAS box, mounted in a 90 degree, anticlockwise rotation (basically hung by the 4 chassis bolts, the output shaft horizontal and the drop arm hanging vertical), on the engine side of the bulkhead, with a standard series steering arm running along the drivers side chassis rail (as it normally does) to a series steering relay mounted just forward of the axle centre line, inside the chassis rail, and then a steering arm down onto the rangie axle.
The radiator was in the back, and everything forward of the relay was removed, and i had a 6mm steel plate to protect the front of the engine
The system was a bit agricultural, but it worked very well. I ran the setup for just over 2 years and never had any trouble with it, i was expecting the PAS box to give problems 'cuz it was the wrong way up, but it didnt even leak!
