Help - Search - Members - Calendar
Full Version: New panels, remove primer or what?
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
Rustyrangie
Hi again all,
What's the concensus of opinion on new panels?
When they arrive they have a coat of paint (primer?) on them. I've heard it said that this is for protection in storage only and should be removed before fitting to a vehicle.
Others say that it's ok to paint over the makers primer.
Obviously it's much quicker to paint over the primer but will it lead to early rust problems?
Obviously I'm talking about steel panels, not aluminium. RR rear wheel arch to be precise.
Any views would be most welcome.
Thanks,
Bob
LR90
Well I had to have use shot blasting to get the makers primer off a new bulkhead before I could get it galv'd. Don't think you'd want to do that if you're planning on applying paint to it.
marsie
When we paint panels we dont remove the coating.All we do is rub it down with 400 grit wet and dry to give a key for the paint to stick to
Rustyrangie
Thanks guys,
I'll just give them a quick rub over with wet or dry then prime and paint.
Leaves me time to find even more rust elsewhere!
Cheers,
Bob
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
