Help - Search - Members - Calendar
Full Version: What is the tension value for Cambelt
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
Warthog
Under the tech section on here. I'm sure it said 21.7Nm? But in the manuals it recommends 14 to 16Nm (for a new belt)
Could someone point me in the right direction for this?
Cheers
Ez question, but gotta make sure!
Bush65
14 Nm in the manual rings a bell, but Land Rover have since issued an instruction to reduce the torque on the tensioner to a lesser value of 11 Nm (from memory - I will have to check).
Reducing the belt tension improves the problem 300Tdi timing belts tracking off with the cr&ppy timing belt pulleys used in the 300Tdi.
Edit:
Just verified 11 Nm torque for the tensioner. Found in Land Rover Technical Bulletin 0008, dated 25.03.98
Note: this is the torque for rotating the tensioner against the timing belt. The torque for tightening the lock bolt for the tensioner is 45 Nm.
Warthog
Cheers Matey,
Never ventured to do one before. So gotta make sure of these numbers!
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
