Warthog
Mar 5 2007, 07:02 PM
Keep having to clean out the Rad and Intercooler on my 90. So am cosidering (long way off, though) the option of moving it to the rear. Mounted in some fashion to the roll cage or similiar?
Have researched a little on doing so, but hav'nt come accross, whether it is wise to install a second pump (electric) to keep flow rate up?
Cheers
Mark
Diff
Mar 5 2007, 11:15 PM
Don't worry, the standard water pump will cope fine.
Regards,
Diff
markwindsurf
Mar 6 2007, 10:22 AM
This is the standard set up on the Tomcats and even given the tortured route the pipework takes we are still using the standard pump has been on there 3 years 300 tdi.
The one thing I would say is filling the system is a nightmare and expect to spend quite some time getting the air out of the system, lots of starting reving for 10 secs, stopping removing caps and re-filling. Other than that it is brilliant, I never clean the radiator out.
Make sure if you are setting it up against a cowl that water can drain away from the front as this is one issue I had....too well sealed.
michael calvert
Mar 6 2007, 07:23 PM
QUOTE (markwindsurf @ Mar 6 2007, 10:22 AM)
any pictures
would get away with the problem of intercooler blocking air flow thrugh a front mounted rad.
or was that youre logic worthog?
Warthog
Mar 6 2007, 10:20 PM
Would, realistically just relocate the Rad to the rear. Then centralise the Intercooler, with only the intercooler to clean, i could live with that
I would think moving the intercooler to the back would cause problems? Not sure what exactly, but?.......Someone will be along to explain
dirtydiesel
Mar 7 2007, 06:26 PM
I run a rear rad with the 300tdi in the gwagon with no problems, it even bleds up really easily
QUOTE (Warthog @ Mar 6 2007, 10:20 PM)
You'd need a sundial to measure the turbo lag.
FridgeFreezer
Mar 7 2007, 07:37 PM
QUOTE (dirtydiesel @ Mar 7 2007, 06:26 PM)
And of course the sundial is already in use to measure the 0-60 time
miketomcat
Mar 9 2007, 08:03 PM
QUOTE (FridgeFreezer @ Mar 7 2007, 07:37 PM)
yeah but doesn't die near water
i've got rear mounted rad in 200tdi tomcat the best thing i ever did and i've an ally sport inter cooler in the front only probs with bleeding is have to fill then bleed top hose then finish filling if you want some pics pm me your email and i'll send you some (as haven't mastered posting pics yet
mike
FridgeFreezer
Mar 9 2007, 11:02 PM
You wait sunshine, the dizzy will be for decorative purposes only soon enough
Here's some piccies of Mike's rad:
Click to view attachmentClick to view attachmentClick to view attachment
russ1
Mar 22 2007, 08:32 PM
How would you go about runing the pipes to the rear, looking into fitting one in the rear of my 90
Jon White
Mar 23 2007, 01:20 PM
Only question is what are you planning to use the truck for?
If its only for low speed work you'll be fine with the rad in the back, but if its for a racer, having the rad in the back does all sort of weird things! Becasue of the turbulent airflow over the back of the car you can have rear trouble getting enough air through the rad - thats why you'll often see racers with big air scoops over the roof to try and force more air through the rads. However they dont work entirely. My mate has had terrible trouble with this on his racer. Its weired cos to me the fans on it blow the wrong way (ie they blow forwards towards the front of the truck) but having tried all sorts of things and tested it this is the way he's found the air actually moves!
Jon
dollythelw
Mar 23 2007, 01:40 PM
if you use the high pressure hitting the windscreen and sit the rad up high it gets round the prob as its dumping into (relatively) low pressure, clean air
russ1
Mar 23 2007, 02:22 PM
mine just a challange 90. so it will be slow work.
markwindsurf
Apr 5 2007, 01:49 PM
Had a quick hunt through and not been able to find any pics where the rad is not covered by spare etc, but it is very similar to Mike's picture Fridge freezer posted.
The ducting in the cab is pretty intrusive though.
markwindsurf
Apr 5 2007, 01:50 PM
Forgot the pic..........
markwindsurf
Apr 5 2007, 01:51 PM
Have never had a problem with it getting hot, except the day we punctured the rad and drained it completely.
Lewis
Apr 5 2007, 04:33 PM
Mark, I'm probably mistaken, but is that the tomcat that did the lagoda a couple of years ago, with Maxidrive portals? I vaguely recall a magazine article
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
