Help - Search - Members - Calendar
Full Version: Q-Max Punches - how handy
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
FridgeFreezer
Since I'm intending to fabricate some sort of dash panel for the 109 I was pondering how to make holes for the dials - hole saws are all well and good but they're not terribly accurate. I acquired rolleyes.gif a 30mm one of these from an abandoned cupboard at work and thought it was neat, and lo and behold after a bit of googling I found that they're not that expensive and you can get 52mm ones for putting gauges into panels:
Q-Max 52mm punch
Thought I'd share it as a useful alternative to hole-saws, and you can get ones that make square holes too (very handy for square switches).
biasbilt
QUOTE (FridgeFreezer @ Mar 16 2007, 12:09 PM) *
Q-Max 52mm punch
I've used them and my dad bought some on my advice, and provided that you are only trying to cut holes in thin material they do a good job. They also don't tear thin sheet like hole saws do. Well recommended.
Toby
LR90
Having spent several (enjoyable) hours cutting and filling out square holes for switches these do sounds like a handy tool.
Lewis
I have a set of those requisitioned into my toolbox at work, they leave a nice bevelled edge on one side too smile.gif
smo
They look very handy for the money, might have to get some of them for fabricating my new dash smile.gif
Rustyrangie
I've used these in the past for making up one off bits of radio test equipment.
The large ones struggle a bit on 16gauge steel but in general they do a great job.
They get a bit pricey if you need a few though.
Have you tried a stepped conecut?
I'll try and find out some deatails and post them on here.
Rustyrangie
QUOTE (Rustyrangie @ Mar 18 2007, 08:07 PM) *
As promised, Found them in the RS catalogue.
they're called a "multicut"
The photo didn't copy, look on the RScomponents site for one if you're interested
All products in this category HSS PG29 European conduit drill
RS Stock no. 325-6616
Quantity Price
1+ £46.90
S Y In stock
Priced as: Each
Dearer than I thought but they do work very well and leave a burr free finish on one side with just a bit of burring on the other.
FridgeFreezer
They're big bucks from RS, as are stepped cone drills. Machine Mart do a set of 3 cone drills for £35 from 4-30mm between them. Frosts do a set of these punches for ~£45 but don't include the 52mm one which is cheapest from the first link I posted.
LandyManLuke
They're nice, they produce round holes unlike drill bits that don't (in thin material). standard tool for fitting VHF aerials in roof panels.
geoffbeaumont
Is it just me, or do the punch keys look suspiciously like bog standard allen keys? unsure.gif
Tonk
stepped drills also get the thumbs up
best thing i use is a cnc punch machine but thats probably a bit big for home use biggrin.gif
HoSS
I actually don't like these for making holes when tidyness is the key. They tend to warp the panel as they pull through, especially if close to an edge.
I have made two dash boards recently, one from Ali and the second from wood (don;t ask- just didnt like the first ones layout, after spending >20 hours on it)
I used the adjustable rotary type of cutter in a pillar drill. Link
makes a clean hole in wood or metal, and is fully adjustable so you only need to buy one. and on top of that you can resharpen it.
101nut
QUOTE (HoSS @ Mar 20 2007, 07:10 PM) *
Works great in a fixed drill press but is 'orrible if hand-held in a power drill ...
AndyG
HoSS
QUOTE (101nut @ Mar 20 2007, 08:49 PM) *
AndyG
Absolutely, pillar drill only.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
