Thought some may be interested on what I have been fiddling with, .............
thanks to Mr BishBosh for help with my back-of-fag-packet drawings
Huge number of hours so far have gone into it, ..............a few more yet to come
but I think now with help from BishBosh and others onto a much neater / stronger solution
The saga of the 'last' 2 winch units behind me I have given considerable thought to a 'proper' system.
Here are my efforts so far :
Basically the plan revolves around completely replacing the rear cross member as a unit,
and re fabbing up a new one out of heavier steel plate, but not too heavy
a similar shape, but to then allow me to have a proper decent mounting for the rear PTO Driven MileMarker.
The basics are to have the winch fitted in a more "Normal" way, thus getting rid of the twisting problem previously
ie allowing the drum to take in as per normal with the rope at the bottom of the cross member, however
I also wanted to be able to switch easily to a tow ball unit for those few occasions I need to tow something
So, I started with 2 "Lumps" of channel,
the main "winch tray being out of 6mm plate, has a tray at the base, an upright, and then a fold at the top for added strength, the "CrossMember" is 5mm
These were just "Tacked" together to allow me to be able to then drill the winch 4x mountuing holes
and mill out the letter box etc, it will still all come apart for welding on.
Click to view attachment Click to view attachment
Seen here as just that 4 holes drilled winch fits -
actually getting 4x holes in exactly the right place 1st time is more tricky than it sounds
Then a bit of shaping:
...............and a taddette of milling :
Then make the 'letter box', this also adds back in huge strength to the letterbox gap, also I have tubed the 2x lower bolts for the winch / Hawse, The letterbox was made bigger so the plasma rope should never really come into contact, ......
but if it does its very very smooth, ..........incuding the way its welded on the back winch tray :
Click to view attachmentClick to view attachment Click to view attachment
Then some top gussets, (there are some inside too, and weld up the bottom sections - made from 4mm
and also I have cut back the "Wings" at an angle for extra clearance :
Click to view attachment Click to view attachment Click to view attachment Click to view attachment
Then modify the old Stainless Steel hawse I have used in the past
and refit with sunken countersunk allen bolts (can then pull sideways without plasma touching allen bolts etc :
Then add the towball unit - detachable without having to do anything other than fit and bolt up in place with 6 bolts :
Next................................. Fitting it
I Have made up large / long sideplates for the chassis sides, and the plates for the cross member to fit to the rear tub etc,
the unit tacks will be cut and the front and rear sections will then be fitted sepeerately so as to get maximum welds
and access, also still to do are the recovery points, ...........but for this I need to get a bigger 'gas axe' as mine 'aint big enough to heat up and then bend up what I have in mind
More to follow .......................
Nige
PS
Yes I work in a mess, ....................it takes years of practise
