Help - Search - Members - Calendar
Full Version: Trolley jack for a 110?
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
doddel
I will be needing a trolley jack for the upcoming jobs on my 110. Unfortunately I am on a very very tight budget. Any good deals around? What would be the minimum requirements?
Les Brock
Hi,
I got a 3 ton trolley jack from Screwfix for £47 IIRC, very stable, very heavy 45Kg blink.gif
FridgeFreezer
Don't buy a cheap one, they struggle to lift it (even if they say they will lift 3+ tons), if you need a trolley jack either buy a good big 2nd hand one, or just face up to buying something decent.
If you don't need it to roll then a decent sized bottle jack can be yours for £20-30.
I have a 3-ton Sealey trolley jack, came with free axle stands and a half decent 1/2" socket set too for around £100 and it's so much more stable than the cheapo ones.
I also picked up a 20-ton bottle jack at Sodbury brand new for £20 that can live in the back of the 109.
welshlaner2
While on the question of jacks does anyone know were i can buy those "safe lock ones" its a bottle jack built into a axle stand.
You place the one under the axle, jack it up, then lock it as if an axle stand, mate as 2 very handy and quick as no need to mess around trying to put the axle stand under, while the jack is holding the truck up. I reckon safer too, about £60 a pair never seen them on sale. Also takes up far less space.
When next in his garage i'll get a pic
Les Henson
I have a ratchet type trolley jack. It clicks as you raise the vehicle and you have to unlock it before it'll go back down. I don't actually like using it as it's an awkward thing to get used to.
Les.
doddel
well, I do have axle stands and a high lift, so it is really for the small jobs at home I'd need the trolley jack.
Mark
If you find your local sealy agent they often have good deals on this sort of stuff. I have a 2.25t sealy jack which came with a nice set of axle stands and have never had any problems with it lifting the 109 or the lardy disco...
Gromit
I had a trolley jack and replaced it with a 10T bottle jack. Much safer as the trolley jack moves as it jacks, and doesn't work on rough ground etc.
Bottle jacks are not too expensive.
welshlaner2
QUOTE(Les Henson @ Apr 27 2007, 06:39 AM) *
Les.
yea i know the one, the axle stand type saves you the hassle of finding room on the axle for the stand and the jack esp. if the jack is big.
Know someone crushed once trying to put a axle stand under a truck for H&S reasons, should not use farm jack ones they are very unsteady
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
