Help - Search - Members - Calendar
Full Version: Oooo Aaaah - You want to make a Roll Cage
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
Hybrid_From_Hell
Hello All,
One thing that comes up over and over again, ......
..........and one subject I get lots of PMs on is 'rollcage' design.
So :
I have taken time out to scan and attatch :
The 'MSA' Rules & Regs re Roll Cages
The 'ARC' Rules & Regs re Roll Cages
Now,
For what its worth many events such as 'Drive Around Days', and currently 'Challenge Events', and of course green lanning do not have set design standards for Roll Cage design, Some comp events have limited 'cage' requirements - if any -
so you CAN do whatever you want.
However, if you are going to all the time and trouble to build a cage, why not take the advice from the above 2 manuals ?
Frankly it doesn't really matter if you do or do not "like" the 'MSA' or the 'ARC', - both offer similar, and dare I say "exellent" advice, (I have copied both as its easier to understand each in certain areas) re roll cage design.
The ARC (unusually for them) defer to the 'MSA', and most, if not all cage design for the ARC matches the MSA - and for good reason - the designs are very proven in competition (read REAL Big Offs laugh.gif) over the years, as the best there are = for the design for survival.
So, have a think,.......... read,.......... learn, ..............
.........and then its up to you (or you can ask on LR4x4 for more thoughts and info and help)
These attchements also cover the constant arguement re CDS vs Blue Barrel ( "Gas Pipe" )
and the weights and specs of each, .............
yes CDS is better ..........but no the MSA .................and ARC allow BB in certain criteria
Enjoy !
Click to view attachment
I'll let this run then .............
Then I will make it Sticky" in 'Tools N Fab' forum,
I have no doubt that as this is a key subject Tony will also pop it into the 'Tech Forum' Index.
Tractorboy16
hi, was then about to say could we have this in the technical archive for future refernce but then noticed it is anyway hpefully white90!!! hint hint
cheers
is awsome, just what i needed for the front hoop fixings.
James
ltwt1981
Just as a help on Regs. The MSA Blue Book is available on the MSA web site in electronic format.
Helps with all the rules and regs.
msauk.org
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
