We seem to get a huge number of 'Posts' and 'Threads' asking about "Which Welder" should I buy for ££££££s etc
I thought it would be usefull to many, both here now and to new members, to have this thread where we all who have a MIG welder(s) to post up the 'Tech Spec' (in the same Format)
good points bad points and price, etc.
I suggest we stick only to Single Phase Machines for this thread
You MUST post up the full tech specs outlined below in the same format so it makes for easy readings for those looking through,
Later On I will do a "Index" at the top of the thread by Make And Model * (now being done and will be updated as they are posted up !)
I would ask that all that post here are HONEST about it, so good and bads reflect real ownership.
I would ask those who post to do it in the following format :
- Make :
- Model :
- How Long have you had it / How old is it :
- Typical Current Price :
- Maximum Welding Current (AMPS) :
- Output at 60% Duty Cycle :
- Welding Wire range in mm :
- Small Large or BOTH re Wire Spools :
- Euro Torch (Yes / No ) :
- Argosheild Bottle - max Size that will fit :
- Weight :
- What is the most typical things you weld with it - thicknesses etc :
- Other standard Features :
- Good Points :
- Bad Points :
- On a scale of 1 to 10 1 being very unhappy with it, and 10 being "Its perfect for me" rate it :
Please Copy the above keep in this format, and then post up below, if you don't know any of the answers shove "Unsure" in the line
Hope this proves to be a Useful long term thread for all
WARNING : OT Replies will be deleted
Nige
Welders Forumers Own, Use, & have Rated - Here's a handy A-Z 'Jump To' Index
Butters AMT 170 - Lesmond of Swindonia
Butters AMT MIG 175 - Mark - 1st review
Butters AMT Mig 175 - Gav - 2nd review
Butters AMT MIG 210 - Orgasmic Farmer
Clarke 151TE (turbo) - Bowie69
Cebora CraftMig 180 - Jon White
Cemont CeMig 320TE - Rogue Vogue
Lincoln 185 compact - Davidlandy
Murex Tradesmig260 - Petes
NBC Butter Autoweld 2 - Fridge Freezer
Portamig 181 - Mike4444244
Portamig 211 - LandyManLuke
Portamig 235 - Will
SIP MigMate 150 Turbo - Jon White
SIP MIGMate 160 Gasless - Lewis
SIP SuperMig 210 - Hybrid_From_Hell
