Russ,
The main dilemma with this particular mod is where to put the intercooler.
You can remove the front cross member and the rad will move back and to the left and sit alongside the steering box nicely , that will get your winch well back and give you a good strong mount and a cracking approach angle. That's the easy bit.
You're then left with an intercooler with nowhere to live. You could try it across the top of the engine - grow some bracketry off the top of both suspension turrets - mounted through the bonnet with a scoop but I can tell you through experience that this is an airflow dead zone and you won't get enough air through the intercooler.
So, what you need to find is a location for the intercooler that will get good airflow through it and yet will ideally make the pipe runs no longer than they are presently.
I compromised in the end and moved the rad and intercooler assy back as far as it would go. Paul Wightman then made me a mount to suit from 8mm plate, so that I have a winch mounted further back than I could with a bumper, in a bombproof welded in winch mounting but still with the intercooler in the direct airflow, splendid
This not the best photo but it gives you an idea -
HTH
Mo
