I have rebuilt your map (again
Try this, I have done the normal MAP and then everything -12, you may find you can't get minus values in the map, yur call !
I have tweaked both RPM Buckets AND MAP levels and Buckets, so look carefully
Report back - this is PETROL ONLY !
Click to view attachment
Be carefull when you fire this up - I am slightly worried your Lucas ECU may be running weak, this map is far closer to what you need in terms of any nearer optimum, but with more advance the more care you need on fuelling, the clue would be if it hunts or lurches at a set crusing throttle, this would be part ECU Fueling and or part bigger spark both could = weak, if so lower the lines including 98 and from 1500+ rpms by 1 unit and then retry, ...hopefully you'll still be ok as the spark is medium soft rather than maximum, but you should feel a big difference - again
At non WOT (ie advance) you now have much more advance which will help with fuel consumption, however you also have more advance at WOT inplaces which will give you a bigger smile, then its blended through the Map itself. The heavy fuel consumption was partly due to not enough advance sort of everywhere ish. You could have more yet but I think your ECU wouldn't fuel it properly 9as above) and it would run weak, you could have a EPROM from Mark Adams to get over this, but frankly cheaper to go full Megasquirt
If when you try it you find its pinking (a sort of odd ratlle and doesn't feel right) back off all cells in all columns 3000a and above by 1 and retry, again I think this should be fine providing the ECU Fuelling is OK, more likley you'll get the hunt at steady speeds than pinking.....
Try this and report back
Nige
