Help - Search - Members - Calendar
Full Version: Tougher and stickier than 'S**t on a blanket' required
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
Hybrid_From_Hell
Hmmm
I need to stick a 90 wheel arch to the ali surface.
Only part of the arch has a "return" the centre part is trimmed flush (as is the ali panel) to allow suspension flex.
I therefore really need to "Stick" the 90 arch on, I have tried silicon, some black go I was told "Was the Biz" smile.gif er...no it wasn't sad.gif
I want it "Bonded" on sowell, that a small 'atomic device' or a very very long session with a Stanley Knife is required to 'remove it' .....
so
Suggestions please ?
And where to get it
Nige
SteveRK
Hi Nige
I guess silicon is more of a sealer than adhesive.
Have you looked at "grab adhesives" ?
I have used a product called Laybond Gripfill from screwfix.com around the house and its basically a combined filler/glue. Waterproof etc, smells a bit like evo-stick and is permanent once it sets.
Screwfix is a useful resource to see whats out there.
pugwash
epoxy not do the job? clean both the surfaces until the ali has no oxde on it and bond them with epoxy- if they stick aircraft wings on with the stuff then it must be strong enough.
Altertnatively go to your local builders marchants and buy smoe non water based gripfill. its the proper version of crap like "no more nails" and really properly sticks- its what i use to stick sheets of 8 x 4 stainlees steel sheets to the wall.
Bull Bar Cowboy
2 pack bonder ............... not cheap though.............. and its removal will be slightly more complex than using stanley knife........ ph34r.gif
Hybrid_From_Hell
2 pack bonder
Nige
jimmy_neutron
QUOTE (Hybrid_From_Hell @ Apr 7 2008, 06:53 PM) *
2 pack bonder
Nige
Double bubble ..
2 pack bonder dries solid ... Thus doesn't flex which isn't good either.
Also doesn't like water all that much. Will work for a couple of weeks, but not a long term solution.
Stainless allen head bolts. At least it will work.
ThreeSheds
QUOTE (jimmy_neutron @ Apr 7 2008, 07:08 PM) *
Double bubble ..
I have recently tried some of this FLEX-EPOXY EXTRA STRONG GLUE WELD PLASTIC - eBay Item 360040064535 but not in the situation you describe. It does seem to stick like normal Araldite, but is flexible - it's holding my Honda fairing together at the mo... Might work?
I presume you have tried Tiger-Bond or Sikaflex?
smo
My money would be on epoxy resin...which i guess is what this 2 pack bonda stuff is!
Phil Hancock
Sikaflex is the stuff to use. It comes in tubes like sillic@nt and unlike sillic@nt it can be overpainted.
tinks
QUOTE (Phil Hancock @ Apr 7 2008, 07:45 PM) *
Sikaflex is awesome stuff! That is if you never intend on getting them off ever again laugh.gif
LEAFERS RULE!!!
Tiger seal! Similar to sikaflex just as claggy! I work in the HGV trade you can repair owt with the stuff! Got me out of a few scrapes on breakdowns at the side of the road just be warned once its stuck thats it dont get it on yer hands either it will stain em, for a smooth finish apply mothers/wifes/parteners best rubber marigold to hand spray a bit of brake cleaner on it n run ya finger over the top job sorted wink.gif
plasticbadger
Search the net for 'Plexus' (www.itwplexus.com) adhesives. They do an adhesive specifically for bonding plastics to aluminium. They are mostly Methacrylate based and cure flexible. Most car manufacturers use their products for gluing together bumpers and stuff (I think the Lotus Elise chassis is glued together with Plexus).
If you can get hold of the stuff it makes most epoxies and Sikaflex look like they're for gluing sparkles to birthday cards.
FridgeFreezer
Another vote for Sikaflex
DefcoL
QUOTE (plasticbadger @ Apr 7 2008, 10:00 PM) *
these maybe?
Bull Bar Cowboy
Double bubble ..
2 pack bonder as used by leading car manufacturers like Audi etc for bonding aluminum bodies is a flexible bonder that is stronger than the material that it bonds.
sikaflex is not anywhere near as tough ..................
Nige......................I will get a product name for you, but I know that its about £60 a throw.................
Ian
madmatt
Definately Sikaflex but you really need a sika gun to put it on neatly. Also you can get a primer for most substances. we use it at work for everything from expansion gaps in concrete rafts to sticking number plates to trailers! It sticks like hell, be warned get it on your skin and nothing short of petrol gets it off!!
pugwash
just bought some "sticks like sh*t" from the local builders merchants
They're not wrong it really does stick everywhere- particularly on your best coat!
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
