Help - Search - Members - Calendar
Full Version: Tyres for Defender 110-Which Measure?
LR4x4 - The Land Rover Forum > Vehicles > Defender Forum
ebdesignDEFENDER
Can you share with me youe experiences about tyres-what can I put on my car without any changes.?
Which oils you use in your DEFENDERS for gearbox,engine,diff.....(mine is an 110 Tdi 1997 Station Wagon HardTop)
I am just a beginer,I have bought my Landy yesterday= rolleyes.gif rolleyes.gif rolleyes.gif
Thanks
bishbosh
Welcome!
What sort of tyres do you want? On road/ all terrain / off road/ extreme off road?
The stnadard size for a 110 is 235 x 85. You can get 255 x 85 to fit with no mods but you will need the right rims (wolfs are good) and you will need to adjust your steering stops.
Check the tech archive for details on what oils to use.
Good luck!
Mark
Moved to the defender forum, as you will likley get some more relavent replies here.
Mark
pux
Hi and welcome, i am running 265/75/16 on my 110 van on standard suspension with no problems at all. And the rims im running them on are black modulars, i have not had to adjust the steering locks either.
Mack
QUOTE (pux @ Apr 8 2008, 05:36 PM) *
sorry to jump in. Are yours 7 or 8J?
pux
QUOTE (Mack @ Apr 8 2008, 10:43 PM) *
To be honest i'm not sure mack, should there be markings on the wheels?? if so i will have a look tomorrow for you.
Mack
QUOTE (pux @ Apr 8 2008, 05:46 PM) *
They should. But not sure in the back or front on those. Appreciated
ebdesignDEFENDER
ebdesignDEFENDER
Can I put rear bigger tyres?
Thanks
Sharp Pointy Thing
Hi Mack
I'm running the the same 265/75, on modulars, with standard suspension (but on my 90) and my rims are 7"
Hope that helps....and stops pux having to clean the give off his wheels to find the stamp smile.gif
pux
cheers sharp but to late i had to wipe away the crap, they are 7j hope this helps, also the tyre i am running are insa dakar which are the same pattern as the BFG MT.
headhunter
QUOTE (ebdesignDEFENDER @ Apr 9 2008, 11:33 AM) *
Thanks
Wot Chav style!
Do you mean wider than the front, or do you mean larger diameter than the front?
John
Mack
Thanks guys. Very helpful.
JST
you should fit the same diameter sized tyres all round, you could fit wider tyres on the rear i suppose....
110 std is 7.50 or 235/85R16
BFG MT are good for mud driving and general off road
BFG ATs are good for on road and gentle off road.
david1701
have to be same external diameter - cos its a 4 wheel drive and you get tranny wind up biggrin.gif (i said tranny heheeheheheee) but wider would work i spose, don't know why would look better tho
JST
QUOTE (david1701 @ Apr 9 2008, 06:52 PM) *
ebdesignDEFENDER
Ok thanks I will go for 235/85 for front and rear.
HiFonics
QUOTE (bishbosh @ Apr 8 2008, 09:14 PM) *
Welcome!
Good luck!
I have 285x75x16 on my 110 on Boost wheels and no lift.
Since I bought the truck I havent tried it offroad but I guess I am going to foul various bits of bodywork. The stops have been adjusted and my lock is similar to that of a supertanker now. Turning around in a road is similar to that Austin Powers scene (20 point turn).
I guess at some point I will get a 2" lift which should fix the body mashing potential but without a change of wheels I guess I am stuck with a container ship turning circle.
Does anyone have any pictures of a Defender with 255/85/16 tyres fitted?
Ben
ebdesignDEFENDER
HiFonics-----NIce ride
pux
This is my 110 as said before im running 265/75/16 on 7j mods with heavy duty springs front and rear..
western
My 110 on 255/85R16 BFG MT's
Jens
BFG MT 35" on 15" with a 4" lift
Exmoor Beast
My 110 on 255/85x16 BFG MTs on 8spokes.
ebdesignDEFENDER
Thanks--The forum is THE BEST___________!!!!!!!!!!!!!!!!!
pux
sorry OT Exmoor beast is that bar going round your 110 a roll cage as in it has internal componets too or is it a just a protection bar?? many thanks
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
