As you all seemed to enjoy the last event so much we have decided to run with the format for the rest of this year and the next event will be on 7 Jun 08, again at Wellington.
If you missed the last one there are some details here:
DDC 29 Mar 08
The rules and regs from last time remain the same ie:
There will NOT be a class system but there will be some vehicle restrictions.
These are primarily:
1. Your Vehicle must have current road tax, Insurance and an MOT.
2. Maximum Tyre size of 33" tall (255/85R16 equivalent).
3. No Simex Style tread patterns, eg FEDIMAs, INSA TURBOs etc.
4. All vehicles must have suitable front and rear recovery points.
A standard fitted towbar is adequate for a rear recovery point. Front recovery points should be a minimum of JATE rings on each chassis leg if a dedicated suitable winch point has not been fitted. Lashing eyes are NOT acceptable. All tow hitches, whether front or rear mounted, should be bolted to the vehicle (not welded) and must be fitted with spreader plates.)
5. Kinetic Energy Recovery Ropes (KERR) are NOT permitted.
In addition you must comply with my standard rules and regs detailed here
The day is designed to be fun and with luck we will have better weather than last time around! I know it was a little wet by lunch time!
The cost is £45 per vehicle, you must pre-register to enter and you can do that by following the links here;
DDC Entry form or emailing me for details.
Those registered will receive directions, timings and scrutineering instructions via email approx 1 week before the event.
Please note that i am away from early May until 22 May so you will not get a reply until after the 22 May if you register within that period.
Entries to date:
1. Jos Greenhow
