Help - Search - Members - Calendar
Full Version: Grease and Grease Guns
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
Hybrid_From_Hell
Is it just me ?
I have nice small grease gun...... which seems to be easier to get into tricky tigher areas for greasing the 90.
I did the grab tub and go for it technique
"Pull Plunger up.... and fill with a selection of screwdrivers spatulas fingers and lots of swearing".....
.....and ended up with more F grease on me,
in my hair (what little I have is now nicely greased) in my F eyes, ears and clothes, .....rather than in the tube
...but I released the plunger and thought "Hummmmm................ not that full" sad.gif
Is it me ?
Is there some secret way involving chickens facing north at the midnight hour and a chant
to help fill these without that "Held by the ankles and dipped in a big vat of grease look" ?
Is there a decent grease gun / filling system, or what tips do you have ?
Or is looking like a really big elephant has just sneezed hard on you a normal situation with these F things ?
Maybe I am missing something here (Careful tongue.gif) but its a right PITFA to ever use my grease guns
Thoughts ?
what do you use ?
how do you fill them?
is there a decent greasegun system to be had ?
Nige
landrover598
Most proper grease guns take a cartrige of grease. unscrew the gun, pull the old plastic tube out, slide in a new one, screw it back together and release the plunger. Simple.
Hybrid_From_Hell
Yep,
Tried those ......they seem big and clumbersome,
hence I bought the "Baby" version, .............which doesn't take a cartridge sad.gif
Nige
landrover598
I've never had problems greasing all the nipples on my landy with my big gun, a flexible head make's life easier, so you can get over the top of the UJ's.
Orgasmic Farmer
biggrin.gif biggrin.gif biggrin.gif been there and done that. My dad was so tight he would only buy the gallon tubs of grease and refill the grease gun by hand. What a PITFA that was. I threw the damn thing away and bought a decent cartridge gun and now only buy the individual cartridges (cost about a quid each from farm stores). The grease gun I have was from the Difflock Store and I must say is of a very good quality and comes highly recommended (if they still do them??). i have a flexi-pipe and a narrow end and have no trouble on LR prop UJs. i would NEVER go back to self-fill grease!
geoffbeaumont
I've also got one of the difflock ones - bought to replace a mini plunger type, which had to be refilled the messy way, after I discovered that it wasn't pumping grease properly any more (tested it after my prop UJ's went sad.gif). Although the grease gun itself is several times the size of the old one, I actually find it easier to use as you only have to get the tube onto the nipple, no messing with with trying to push down a plunger at awkward angles. It also holds a huge amount of grease, so I've not yet had to change the cartridge.
Orgasmic Farmer
QUOTE (geoffbeaumont @ Apr 12 2008, 11:02 PM) *
Ah , but you probably don't have 2 balers and a mini digger! I can get through 2-3 cartridges in a day if I feel the urge to lubricate! tongue.gif ph34r.gif ph34r.gif
Unfortunately the Difflock store no longer lists the grease gun. Just be prepared to pay around £20 for a quality item and you should be OK
Bowie69
Never had a problem with the grease pots with a plastic ring in the top of them, specifically for filling the said grease guns smile.gif
David Sparkes
QUOTE (Bowie69 @ Apr 13 2008, 01:50 AM) *
Maybe, maybe not.
I've mainly used Wanner grease guns (They've had a name change, but I can't remember the new one) and these have a floating cup/disc seal in them. This means that when you compress the spring by pulling a chain out of the back of the storage tube, the floating cup stays at the head end. Unscrew the head, invert the tube over the 'plastic disc with hole', press slowly but firmly, and the grease is pushed in with no air as the cup pushes the air out past the spring.
You can buy trigger grease guns that look very similar, but 'save' on the floating cup bit. These make life more slimy, as expressed by the others. The trick with these is not to retract the piston, THEN fill with grease, but to invert the tube over the 'plastic disc with hole' then co-ordinate your efforts such as the tube is pushed downwards on the disc, AT THE SAME TIME, slowly pull back the plunger. This prevents air getting into the guns grease container.
The only virtue of this method is that it's better than the 'knive, spatula, finger' method, but it still doesn't beat the cartridge syestem, which is probably better than the Wanner floating cup system.
As described earlier, I should think your local agricultural suppliers is the best place to go, as I can't see the farmers wanting the grease yourself up system, when working in areas that are naturally dirtier (with small particles) than a garage.
HTH.
Hybrid_From_Hell
Yes Very helpfull thanks david.
If you can remember the new name that would be brill
Nige
green110
http://www.stephenslube.co.uk/wanner_lubrication.asp lists Wanner grease guns (I haven't got one).
I like the trigger guns (as opposed to side lever) as you can then hold the fitting onto the grease nipple with one hand and pump grease with the other. Flexible pipes are good and I'm a firm believer in changing the quick coupling on the end at regular intervals. If greasing is a clean easy job it gets done!
As an aside some cartridges are better than others; some have plastic ends that break instead of tearing off cleanly (don't use Texaco tubes) and some seem to come factory fitted with air pockets.
Gus
David Sparkes
Thanks Green110, I was thinking the name began with 'A', Abnox it is, they have obviously realised the benefit of keeping the positive kudos of the Wanner name.
Frightening price though!
I have always used the one handed gun.
Angle of attack (of the nozzle onto the nipple) can be critical, and some nipples just won't seal properly, although I seem to recall that some 4 jaw nozzles are available.
I've done all propshaft UJs with this gun, although sometimes the prop has to be rotated to give access.
BMC Mini front suspension can be another test, successfully met with this gun, as the internal grease pressure can require a lot of force to get more grease in, and leave the gun locked onto the nipple, where the pressure release screw on the gun comes in handy.
I see there are some links to useful tips at the bottom of the Stephens Lube page.
Orgasmic Farmer
Yes i forgot that mine is a trigger setup which means you can pump with one hand while holding the nipple in place with the other. Side handle pumps are impossible with a flexi-hose. Mine also has a handy 2 position handle which gives lower pressure but high volume or high pressure/low volume. Handy for forcing grease into tight spots or blocked nipples!
clbarclay
Cartriges are the best compromise I've come accross, they still get a bit messy, especially when the seal on the plunger is old and you get some greasee leaking back past it so when you pull the plunger back it squerts out round the releasing leaver. I always change them with an old rag to hand.
Deffinantly get a long flex for it, inveriably I find most machines have at least one nipple thats impossible to get a standard rigid pipe on to. One of the guns at home has the flex of an old tub greaser (ie very long). This is good as the gun can be placed ona firm surface and pumped one handed whilst the other hand hold the end on square or coil it up a couple of times and with one hand holds the coiled flex and the gun with just a very short length of flex between the hand and nipple whilst the other hand is free to pump.
As said above some of use get through a lot more grease than others, Nige be glad in your lubed up state you didn't have to go and grease a combine mid season, you would probably have ended up looking like a wicker man.
Personanlly I much prefer sealed for life bearings or if you can't get away with them then an auto greasing system. on big cultivators this can be a ££££ option, but given some cultivators can take 3/4 hour to grease they can be well worth the cost.
Les Henson
A normal tin of grease that you buy from the likes of Halfords have a plate with a hole in the center of it on top of the grease when you take the lid off. You just push the grease gun chamber down and the grease is forced straight into it.
Les.
alan kemp
I use the side handle one, I have three for some reason. They spill more grease out of the end when pumping than goes in the nipple. Tried changing the heads but still have the problem. Tried different nipples but the you are stuck with the small ones on a propshaft. Sometimes they work fine but generally, I end up with a big dollop of grease on and around the nipple.
Also, I wanted some waterproof grease for various jobs. My supplier sold me some but he has written on "water proof grease" in ink and I am not sure its the right stuff. I am really looking for water proof, very thick and in a cartridge. Where can I get some of that?
green110
http://www.rocol.com/lubricants/english/ma...gs/prod0058.php
Rocol Sapphire Aqua 2.
Most engineering suppliers seem to deal with Rocol; they make sealants, adhesives etc. I'd be very wary of grease identified with a marker pen!
Gus
cipx2
This is what I have in my toolbox: http://www.amazon.co.uk/Draper-12681-Pisto...e/dp/B0001K9OWO
It's small, 130 cc, easy to fill - bit like how you fill a syringe, one hand operation.
For more heavy duty jobs I have one similar to this: http://www.northerntooluk.com/products.asp?partno=150305E
It can use cartridges or bulk grease, manual or air operated, comes with flexible or rigid adapter (mine came with a set of adapters, various sizes).
I only used it once on the LR, when I bought the vehicle to properly get the grease through all 4 heads of the UJs (I had to use compressed air). After that, the small grease gun did the job perfectly and its my favorite.
steve_d
I was given a broken, hand-me-down, Wanner gun which I repaired. I've had it for forty years now.
Steve
Boothy
Gentlemen,
Money cannot buy a decent grease gun because nobody makes one any more,
I am a maintenance man who has worked on the Railway signalling department for 31 years now, and have greased more cranks, fittings and ancient signalling things than you can imagine.
Its fair to say I've examined and serviced more nipples than a retired breast surgeon, and tended to said nipples with every type of grease gun imaginable, and frankly none seem to last above six months.
Some days spent on heavy mechanical signalling mtce can result in excess of 15 tubes or so being used, before the chippy opens.
Best gun without a doubt 4 jaw side lever, cartridge or refillable, probably costing in excess of £60 or so, especially ones from suppliers that can supply new springs, seals and jaw sets at point of sale.
If not any cheap crap and be prepared to sling it regulary and get another, but always check your nipples are clear before trying to force grease past, because clogged greaseways and nipples will seriously damage your tools seals.
Br00n1e
bought my wanner one of the bay, works great
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
