Help - Search - Members - Calendar
Full Version: home made winch bumper
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
madmatt
I made this over easter what do the pros reckon, Its 6"x4" box section 10mm walled with six points of mounting to the chassis
Click to view attachment
FridgeFreezer
madmatt
QUOTE (FridgeFreezer @ Apr 13 2008, 07:46 PM) *
One step ahead there! it had them a few months back, its a 130 to with the uprated jobbies. It only weighs 42kg without the winch LOL!
Mo Murphy
Mo
simonr
May be just me - bit it looks a bit delicate. I would have a chat with Nigel From Hell about beefing it up a bit. Some gussetts and maybe increasing the thickness of the winch tray to about 25mm would improve it.
Si
Night Train
Nice work there.
The only thing I would say is are you going to notice those corners when walking around the front of your vehicle?
Nice touch with the twin towing jaws. I used to fit mine wth the pin horizontal to take an A frame and be a jacking point as well as a mounting for a removable winch tray with a matching pair at the back.
Paul Wightman
I see you've not tubed the holes through the box section bumper, why?
madmatt
Thanks for the comments guys.
Its been on a week now and I can't say the square corners have been a problem certainly not walking around them.
Paul that box section is 10mm wall, twice the thickness of any standard winch bumper the tow hitches also have 10mmn spreader plates behind them. I'm never going to pull the bolts through the front face with that quantity of steel there. If it had been 4 or 5mm steel may have been worth considering more. As it is now all threads are inside the box so the won't get covered in cack like they would going right through, oh and I dred to think 12 M16x220mm bolts would cost let alone weigh!
This was designed with commercial work in mind not all this driving upto your neck in mud milarky and then winching yourself out for 5hrs LOL!
clbarclay
QUOTE (madmatt @ Apr 15 2008, 04:49 PM) *
Would cost less than a tenner for the bolts and 12 would weight approx 4.5kg
http://www.fastfixdirect.co.uk/code/naviga...arch=Show+Items
madmatt
QUOTE (clbarclay @ Apr 15 2008, 07:12 PM) *
Its irrelevant now as the job is done now and I'm not changing anything.
Paul Wightman
I'm a little confused here, the box is 10mm wall, you have 10mm spreader plates behind the tow hitches ( I assume inside the box) and the holes are tapped M16?
madmatt
QUOTE (Paul Wightman @ Apr 15 2008, 07:32 PM) *
I'm not sure why your confused! I never mentioned anything about taped holes., your right the box section is 10mm wall with 10mm spreader plates yes inside the box with nuts and washers on the back,
Night Train
So the bolts are only on the front face with a plate behind inside the box of the bumper with, presumably, access for the spanner to hold the nut still. That should work.
On the back of my 6x6 there was a peice of 20mm plate with 4 M16 tapped holes to hold the hitch on. The plate was then welded onto the 6mm plate that made up the rear crossmember. Never had any problems with it. Never had any problems with the pin hitches welded on either.
madmatt
QUOTE (Night Train @ Apr 15 2008, 08:02 PM) *
you got it mate! yeah it works at the end of the day the chassis will probably give up first lol!
Paul Wightman
QUOTE (madmatt @ Apr 15 2008, 07:43 PM) *
Now I understand, should be up to the job.
Hybrid_From_Hell
Si...Paul
Your both wrong.
Actually I think it looks better 'on' the 110 than 'off' it, ...........nice job smile.gif
Nige
(Even though its made from hopelessy thin sheet tongue.gif)
Paul Wightman
Thought YOU'D be impressed Nige!
western
Nice work Matt, looks really good on the 130.
madmatt
QUOTE (Hybrid_From_Hell @ Apr 15 2008, 10:26 PM) *
Si...Paul
Your both wrong.
Nige
Cheers thanks for the comments its on a 130 practicality was more of an issue than styling
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
