Just after a bit of knowledge from an adult. I downloaded the 4 link calculator for excel from Pirate 4x4 and stuck in the figures for the Disco trayback (with standard LR setup) having got underneath with a tape measure. What I get is
Anti Squat - 145%
Roll centre height - 22"
Roll centre angle - 10 degrees (roll oversteer)
Does that sound about right for standard?
I then modified the figures for the Nissan rear axle I am currently fitting which basically means the upper axle mount is about 4" higher than the LR setup and this changes the figures as follows
Anti Squat - 174%
Roll centre height - 24"
Roll centre angle - 7 degrees (roll oversteer)
I can get the figure back to something approaching the LR ones by either raising the chassis mounts for the A-frame or by using longer trailing arms (like Gigglepin). So what I want to know is whether the figures for the Nissan set-up fall within acceptable levels (assuming 99% offroad usage) or is it going to be horrible to drive/problematic on climbs, etc?
Cheers for any informed input
Mark
