QUOTE (Corrode Finger @ Apr 28 2008, 10:18 AM)
Hotrod,
I am keen to have a go at trialing, mentioned this last month when the brickkiln site was mentioned, but was unable to attend due to MOT expiry etc.
When and where is the next one?
Portland seemed a bit far to be fair, for a first time out.
Also what are costs, requirements etc?
Hello Mr Finger...
Next SCOR trial is back at Brick Kiln Farm near Four Marks (near Alton) on 25th May - SCOR run pretty much one a month around the southern area (check out www.scor4x4.co.uk for calendar). Can arrive & join club & drive.
Hants & Berks LRC is the other regular trial organiser in our area (if your L/R is basically standard)
Not much required for trialling - front & rear tow points + tow rope, fire extinguisher, carb return spring that's about it
Not sure what you drive but Series Landrovers often make fools of big rubber coilers - down to the driver!
SCOR charge £20 entry. You don't use much gas as there's not many miles covered and if you take it easy shouldn't break anything much in road-going class trails (RTV)
If driving round & round at 'Play Days' is getting boring, try trials for a friendly day out and challenge yourself a little (without major damage risk)
Simon
