The PTO hole is round, but I'm clean out of round holes, but happen to have some square holes, so the hole is now square to accomodate the 5-inch sq x 4mm thick square hole I have in stock
Also - tub mounting tabs are sooooooo yesterday - those piles of weld ruin the subtle contours of the rear face of the crossmember and it would be reely kewel if it was a dead flat surface for some plonker in a corsa to whack into. So forsaking the Lord on this one occasion, I set about the 5mm steel sheet with my junior hacksaw, 'Big Boy' file kit, and a re-chargeable drill from B&Q.
Some piccys for those of you that have taken the bread and wine today and are therefore incapable of standing up
The 4 x holes at bottom, centre are for a NATO hook by the way.
Click to view attachment
Les
