Help - Search - Members - Calendar
Full Version: Milling Machine Cutting Tool Wanted
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
chrism
Hi guys
Anyone know where i can get a tool so i can machine my own ally fairleads out, i have access to a miller but it doesnt have a tool for the job. Its the one to put the radius on the inside edges. If i cant get one i think i will just use my router slowly!
Chris
freeagent
I made some of these on a CNC router, with the cutter spinning at about 15,000 rpm.. biggest problem i found was washing the chippings away from the cutrting tool, as routers don't have coolant spray like mills.
It worked OK but we did have some problems with chippings melting and sticking to the cut surface...
Mark
Chris,
You don't say whereabouts you are... First place I would look would be eBay - search for 'corner rounding' cutters, then my local 2nd hand machinery place - G&M Tools.
Failing those, somewhere like J&L Industrial will likley have one if you want to pay for it....
hth
Mark
steve_d
If I remember correctly from other threads you will buy a ready machined fairlead for the same money you will pay for a new cutter (£75+).
Steve
chrism
I know they are available pretty cheap but i still need to make my own to my own length, i also have a couple of friends who want some, so will soon find a home for a 4m length of ally. If i have a tool for machining them then i can always run around them again whenever i want to get rid of any chip etc. I think i may have found one through the a local company who are fabricators etc etc. But anyways im in north shropshire if anyone knows anywhere round here
Chris
Astro_Al
Try on ebay USA ( www.ebay.com ) - I bought some nice big cutters on there for peanuts. There are a lot more decent tools on the American ebay, and they are generally cheaper.
Cheers, Al.
chrism
Just found this, may be worth a try, just need to work out what size radius i want to go for and what size slot to run it through, im guessing around 20-25mm for either 11 or 12mm plasma rope
http://www.tapdie.com/html/corner_rounding...ers___metr.html
integerspin
Look up Barrett used tooling. I bought quite an assortment of used tooling off them a few years ago.
I don't remember where they were, somewhere up north no doubt.
chrism
Thanks integerspin, just phoned them up and they have some in stock!
clbarclay
Another place for cutting tools (amounts other tools) worth a try a Cromwell
http://www.cromwell.co.uk/category_page/3926
Chunky
Here........... http://www.jlindustrial.com/cgi/jisrhm
first class service .................next day delivery etc etc
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
