Hello!
Although my Warn electic winch never has let me down, I am getting rather tired of strugling with lots of batteries and alternators... (current setup : 4 110 AH batteries and 2 100 A alternators...)
I have had a number of different ideas about either hydraulic or mechanical winches. Managed to aquire and old - but fully functional - toyota mechanical winch, which my first idea was to run directy from the crank shaft. The only drawback of this setup was that the line speed would be scarily fast - some 12 metres pr minute - and some of the more knowledgeable members of this forums suggested that the winch itself might not be up to the job.
So, determined to the things right the first time, I have slowly been aquiring the diffent parts needed to make a hydraulic winch.
I have just bought the last part, namely the hydraulic motor for the winch.
Hydraulic power for the winch will be delivered using a ZF74 pump with electric solenoid valves and oil cooler.
The winch is an old toyota mechanical winch with a gear ratio of 1:36 and a bare drum radius of 0,04 metre. I should note that I have never been able to confirm that the winch indeed should be "toyota"-made - I just know the seller told me so.
The purpose of the winch is self-recovery, and the odd job of pulling some trees down. I do not participate in competitions. Therefore reliability is far more important than line-speed. Actually I think I would be rather scared if I were to use some of the really fast setups for my purposes....!
Calculating the pulling power of the winch:
From the technical specifications of the OMM32 (se below schematics) it seems that it should be able to spin at about 430 RPM at a flow of 13 litres pr minute, and deliver a torque of 4.5 daNm at just under 120 bar pressure.
For calculating the Drum Torque of the winch I use the following formula:
Drum Torque (daNm) = Motor Shaft Torque (daNm) / Gear ratio
which gives a Drum Torque of 162 daNm (4,5 daNm * 36)
For calculating the Line Pull I use the following formula:
Line Pull (kg) = Drum Torque (daNm) / Drum Radius (m)
Which gives a Line Pull of 4050 kg (162 daNm / 0,04)
This is calculated as a bare drum line pull, and generally under optimal conditions. Still it is a line pull I am quite happy with - if I need any more pulling power I can just double back the winch line using a snatch block.
Calculation of the line speed:
For calculating the Line Speed I use the following formula:
Line Speed (metre / second) = ( Motor Speed (RPM) * Bare Drum Radius (m) ) / ( 9,5 * Gear Ratio )
Which gives a line speed of 0,050 metres pr second (430 RPM * 0,04 m) / (9,5 * 36)
This should equal a Line Speed of 3,0 metres pr minute, which is also a number I am quite happy with.
Winch Power Consumption:
Click to view attachment
Using the specification sheet for the OMM32 it seems that the power delivered from the pump to run the winch at above specifications should be about 2.5 HP.
This is also a figure I am quite happy with, as this should be well within the limitations for running the ZF74 pump of a normal vee-belt.
As stated in the topic title, my normal field of expertise is in the computer networking field... This hydraulic thing is quite new - however all the data and specifications of the different components are available on the web and I hope I have been able to puzzle it all together in the right fashion - should there however be some blunders iin my plan I would really appreciate some guidance....
