The kind of thing which lets you reduce the pressure to the rear (or front) brakes to improve the balance of your braking.
The reason I ask is that all the suppliers of such devices say something like 'for track use only'. I spoke to one establishment who said they were not suitable for SVA.
The reason I'm interested is the SVA seems to include testing to see that the proportioning of the brakes match the weight distribution of the vehicle. My front and rear calipers are the same - so I have 50/50 braking but not 50/50 weight distribution.
I have a proportioning valve from a Disco (kindly donated by Mark) which at low pressures allows the same pressure through to the back, but at higher pressures the rate of increase at the back is lower than the front. I'm not convinced this is sufficient - at least for SVA - so how does one 'fix' it?
Si
