Following thoughts on here previously I bought some blade fuse holders from VWP, their FBB8U @ £3.95 ea, and here's my step by step guide on fitting them.
The old wiring was a mess, with an assortment of fuses in the wrong ratings, some mains-plug fuses and a couple (ahem) of blown ones wrapped in tinfoil.
I pulled the big bracket out and trimmed a little of the strengthening rib across the bottom to clear the new fuse boxes...
Holes are added to take the mounting screws (although one was too close to the edge and became a slot - no matter), so next is the heart-stopping moment of snipping into the main loom. It's this stage that has put me off the whole process for two years or more.
I transferred the wires across one by one to the new fuse boxes, methodically and slowly. I didn't label any of the wires, just kept them in order and moved them one at a time.
And here's the installed creation. In Blue Peter style I'd labelled each slot while the backing plate was on the bench, and this method gives me space for a few spare fuses at the bottom.
If I'd thought ahead I'd transfer the wires for the other four fuses onto the spaces at the bottom of the new board, but I've got no idea what they do (although evidently only the top two do anything noticeable because they're the ones that had fuses in them - any ideas?). It was also a good opportunity to tidy up the wiring for the stereo which has hung loose in the footwell for the last eight years
