jcwcooper
Jun 16 2008, 09:37 PM
My trolly jack gave up the other day so im going to treat my self too a new one, I dont want to go OTT been looking at this from machine mart
http://www.machinemart.co.uk/shop/product/...nsmission-jacksCan anyone recomend it or another one?
Thanks
Dave.
MogLite
Jun 16 2008, 09:42 PM
I've got that exact one - had it for 2-3 years - its great. Its not too heavy to lift/move. I had a 3 tonne previously and that was a bit of a monster.
If you are in the habit of lifting a tall Land Rover via the chassis - you'll run out of lift, but under the axles is fine.
MogLite
Jun 16 2008, 09:58 PM
This is my old trolley jack, but this wonderful piece of bodgery still gets plenty of use with the Clarke jack - I've got a 2nd longer one, but that does get a little outta control with 2 tonnes on it
Click to view attachmentClick to view attachmentClick to view attachment
ciderman
Jun 16 2008, 10:00 PM
For a bit more cash you can get one of these ,
http://www.primetools.co.uk/getinfo.php?product=7018 But for occasional use its probably over priced ,
They are damn good and have a quick lift , Ideal for Land Rovers
clbarclay
Jun 17 2008, 04:30 PM
I'm not a fan of the cheap trolly jacks, mainly because the control (or rather lack of it) when lowering them. I've come across some which wern't much better than a ratchet strap for lowering.
We got a hydraulic trolly jack no that long ago at home very similare to the machine mart one above (but 3 ton). The quick lift pedal on the side is a good idea, poorley executed and god removed from ours in short order. As above the control for lowering veaves a lot to be desired, especially when you are used to one with a screw thread.
Not sure what the lift hight on ours is but they are never enough. That extension section is a good idea moglite.
6cyltdi
Jun 17 2008, 04:38 PM
Les Henson
Jun 17 2008, 05:59 PM
QUOTE
Product Description :
This 3 Tonne Heavy-Duty Trolley Jack is ideal for use either in the home,
A bit excessive if you need to move the sofa
Les
landmannnn
Jun 17 2008, 07:29 PM
linkThis is a link to better clarke jack - 3 t with 520mm lift weight 17.5kg - inc carriage £41.
edited to say "possibly better"
jcwcooper
Jun 17 2008, 09:12 PM
Thats the one I had which gave up......lasted 12 months
thanks for the input........no ones mentioned what they are like too lower the one above was very difficult to lower slowly.
Dave.
Night Train
Jun 17 2008, 10:22 PM
QUOTE (dougstar @ Jun 17 2008, 07:09 PM)
I have got this one and it does what it says on the tin. been really good for the 12mths i,ve had it
Not the quick lift i know but extra tonne, starts off lower and finish's higher with a longer handle too all for another £6
o and a nice big sturdy lifting base to top it off
Just my 2p's That's almost exactly the one I bought 20 years ago and it is still going strong. Never had a problem with it and very controllable up and down. Mine had a lift head cup on it that was around 7" diameter, made it very stable when lifting awkwards shaped bits. The socket under the cup is really wide and so good for adding different heads to suit differnet uses. A good one is an asymetric cradle for lifting in the middle of a front axle to clear the diff.
muddy
Jun 17 2008, 10:58 PM
I have
This one and i like it very much, being able to put it under the crossmember or front bumper and be able to lift the vehicle hi enough to change springs etc.
After oiling the handle the lowering action was much better and the quick lift is very useful. Also having a longer chassis means you can jack up on the axle whilst standing nicley upright at the front of the motor
Will.
mike4444244
Jun 18 2008, 02:04 PM
If you have a costco near you get the 3 ton one from there, its fantastic but flipping heavy IIRC its about 40-50kg ish will go low enough to get under a lowered 190 or an mx5 and will lift high enough (under diff) to get a 33" landy tyre a foot off the floor! was around £50 IIRC
Mike
pete3000
Jun 18 2008, 02:20 PM
I bought myself one of these a few years back and it has been superb.
http://www.justoffbase.co.uk/2-Tonne-Heavy...per-TJ2-HD?sc=9The main reason was the height of the lift, which is 500mm. You can also remove the cup and fit a draper transmission cradle for lowering the gearbox/transfer box.
http://www.justoffbase.co.uk/200kg-Transmi...-Draper-ATJ2-TCOr if you fancied a bit more they do a three ton version but not sure if cradle still fits socket.
http://www.justoffbase.co.uk/3-Tonne-Heavy...per-TJ3-HD?sc=9best of all free P+P over £50.
I had my draper 2 ton engine crane hoist from here also.
pinny
Jun 18 2008, 02:37 PM
QUOTE (6cyltdi @ Jun 17 2008, 05:38 PM)
this is exactly the same as mine came from sealey about 4 year ago good jack never let me down doesnt creep either i had to cut the handle down to get it in my escort van but otherwise ok chris
OilIT
Jun 19 2008, 06:18 AM
had one of these
weber for about 18 years - not had to even look at it - fantastic control on the downward cycle, good to move stuff (have spun a 88" round in the garage on the jack with no problems
and also good for jacking up fallen down apple trees - oooh arrrrr
GavF
Jun 21 2008, 12:53 PM
Thats the same jack as the one in Screwfix,
http://www.screwfix.com/prods/51457/Automo...nne-Garage-JackSo could save a tenner if the store is local to you.
jcwcooper
Jun 21 2008, 02:37 PM
Bought the one i posted in the end hopefully it shouldnt let me down......alot more beefy than the old one.
Dave.
