Help - Search - Members - Calendar
Full Version: Stick welding and a MIG helmet
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
Les Henson
Can you use a MIG auto helmet for stick welding? I vaguely recall something about the UV from stick welding being brighter and you can't see the weld pool.
Les.
Tonk
i would, just adjust brightness of helmet.
ciderman
Les , 9EW filter for mig (Approx 200 amp), 11EW for stick/arc
carl hurst
Most auto masks are adjustable between 9 and 13 so you should be fine,
Carl.
reedx
Les
I have an auto darkening welding helmet (shades 9-13) and the instructions give the following guidelines for use with arc/stick based on current used
Amps ---------- Shade
20 - 40 -------- 9
40 - 80 -------- 10
80 - 175 ------- 11
175 - 300 ------ 12
300 - 500 ------ 13
Colin
www.REEDX.net/landrover
Les Henson
Les.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
