Help - Search - Members - Calendar
Full Version: Welding aluminium. Tack with the mig, Weld up with tig?
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
Steve 90
Any alloy welding experts.
Does anyone know if I will have problems welding some 2mm wall alloy tube with the Tig after tacking it in place with the MIG. Its one of those trial and error fit type jobs and it will be easiest (as it needs to be done on the Landrover) to tack it all together with the alloy wire in the mig before Tig'n it all together. My concern is I have done simillar with mild steel in the past only tacking together with MIG then Gas welding. Everytime Ive tried to gas weld over the Mig Tack its caused problems. I dont know why, It just has.
So will it be OK to Tig over what has been tacked with the MIG?
Thanks.
Steve.
Astro_Al
Just make sure its clean before you tig it. Should be fine.
Al.
dollythelw
grind em down with clean softy Steve, then do all the usual gumpf and it'll be fine smile.gif
Astro_Al
Er, yeah. I just meant clean it after as well in case there is crap from the mig (soot or whatever).
alan kemp
When I was a sheet metal worker eons ago, we used to use soap to stop ally sticking to soft pads (many tears). Is soap still used? If so does that affect the weld. Our welder used to gas weld and I think cleaned the ally with wire wool.
LandyManLuke
QUOTE (Astro_Al @ Jun 19 2008, 12:08 PM) *
In case?! there'll be loads, in my experience.
It's called 'smut' believe it or not ph34r.gif . 5356 is particularly bad for it, but easier to weld with. 4043 produces less smut but you need to run it in at a rate of knots - around twice the m/s wire speed, I've found. In either case, increasing the gas flow (pure Ar) helps a lot.
dollythelw
4043 leaves a weld that wont annodise because of the silicone content.........
(but its a nice easy grade to work with for the same reason)
easier to use flap sanders Alan - no cloggy, my fave cleaner for ally is a scotchpad material buffing wheel on a battery drill, quick and leaves a nice finish smile.gif
Bull Bar Cowboy
A stainless steel wire brush is preferred by the purists for preparing ali..............
I tend to use a 3M strip & Clean wheel on the air die grinder ..........separate wheels for Ali, SS, and Mild Steel.....
Ian
nzs2a
i wouldnt grind the ally where your going to weld,, compounds from the grinding disc will stay in the ally and will make your weld have black bits in it,, just use a file or grind then file.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
