Help - Search - Members - Calendar
Full Version: what gun & grease cartridge do i get???
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
dougstar
Ok now i have searched the forum on this matter and did not find the answer i was after.
So i currently have a small manually loading grease gun that does the job fine but the new water proof grease that i have found is a pain in the booty to load into the dam thing.
So i,m after a good quality grease gun that preferbly takes a cartridge (for ease and cleanliness) providing that i can get my paws on a good water proof grease that is suitable for both wheel bearings and propshafts.
have spotted this and this one so far.
so what are your opions please guys?
And more importantly is the grease i dont want to be putting any old cra% in cause its easy and in a cartridge,if i have to bulk fill i will.
thanks in advance forumers
Dougie.
white90
I have the first one and get the cartridges from the farm suppliers locally
works just fine
Orgasmic Farmer
i have a one handed one like the Silverline one on Ebay (but better quality) and i would never go back to the 2 handed one again. Trouble is I have to use a flexi hose to get to the nipples on most of the farm machines and you end up needing 3 hands otherwise. If you have a 2 hander then you really need to use a rigid pipe and that limits your apps... I also get the cartridges from the farm supplies. Last lot were 99p each if bought in a 10 pack!
BTW Silverline seem to be pretty good for a budget range and have a pretty good guarantee.
dougstar
Whats the grease you lot a are gettin from the farm supplies?
is it water proof and good enough to go in my propshaft and wheel bearings or do i need to spend a little more cash
white90
I'll look I think from memory it is FUCHS grease
and it goes on my props/ujs
freeagent
Best grease i've used is JCB blue waterproof grease...
works out just over a pound a tube if you buy 12, and is far superior to the cheap brown stuff.
dougstar
QUOTE (freeagent @ Jun 24 2008, 01:29 PM) *
that sounds what i,m after to be honest this stuff i,m using is suppose to be sh1t hot and is blue and water proof marine stuff but in a cartridge / tube would be better for my new none messy gun (when i choose one that is)
Where do you order from off the net or local supplier?
Let me know please and i'll get some ordered asap.
Regards
Dougie
freeagent
I get it from the farm next door to my dad, the farmer runs 3 JCB diggers, and gets through loads of grease..
i suggest you look on the net for blue lithium grease....
Madcowz
I use this:
Click to view attachment
from the local Farm (supply).
It's the blue waterproof stuff.
ciderman
Brilliant stuff , I also still have the grease gun from when I had a new 3CX back in 1990 , Its the best grease gun I have ever used , never needs priming and works a treat
JCB still do their own grease guns but they aint a patch on the early ones .
Steve Hiatt
I question, having been advised by one much wiser, whether waterproof grease is what you want for wheel bearings or propshafts.
The grease won't eliminate water ingress into your hubs or prop. Better to absorb the water than leave it there in droplets to rust any exposed bits.
ciderman
Exactly , If you have water migrating to your bearings , you have seal failure some where along the line .
Steve Hiatt
QUOTE (ciderman @ Jun 24 2008, 06:23 PM) *
Agreed, or condensation. So waterproof grease would be worse as the water would be free to rust away, whereas your standard grease will absorb a fair degree of water before allowing any rust to your bearings.
Les Henson
I use JCB blue (which I get for nothing smile.gif )
Two grease guns - the two-handed type that takes a whole catridge, and a small one-handed one that was originally supplied with S1 Land Rovers.
Les.
dougstar
I fancy this blue JCB grease now everyone is on about it but have had a real good scout around to no avail sad.gif
Come on guys where can i get some at a decent price mail order or not
even got myself a genuine 3CX grease gun on cidermans advice (thanks)
Come on i know one of you can pull this out the hat for me
Dougie
ciderman
I have got the blue grease in the past from Holt JCB in Avonmouth , But I guess you have already tried your Local JCB dealer if you have already got the grease gun.
WALFY
Jase I think E-Bay was his friend with the grease gun
Chunky
These are the best grease guns I have come across, had one in constant use for over 10 year's, ............ but they are not cheap, (sit down when you enquire) worth ever penny, and as user friendly as you can get.
http://www.macnaught.com.au/sub_level.php?...asing_Equipment
dougstar
QUOTE (WALFY @ Jun 28 2008, 06:17 PM) *
What would make you think that Walfy??
Ican see that i may need to keep an
on you..
WALFY
Following on from all the talk on here I went and purchased a new gun as well. Strangely someone by your name also purcased 1. So I assumed it was you.
dougstar
QUOTE (WALFY @ Jun 29 2008, 03:43 PM) *
And there was me hoping for a more extravegant explanation like
Never mind, anyway have you recieved yours yet? is it any good only think mine is in the post office awaiting my colection tommorrow.
Then i'll track down this grease and have me a grease-a-thon on the drive with my disco tongue.gif
pinny
QUOTE (dougstar @ Jun 29 2008, 03:55 PM) *
i use total multi complex grease which is red which is basically the same as jcb grease as i get this from work
dougstar
QUOTE (pinny @ Jun 29 2008, 04:10 PM) *
All brands/types considered so long as its,
1st) good quality
2nd) easily available in a cartridge
3rd) cheapish (of course)
Will go on another search via the World Wide Web in a bit
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
