Help - Search - Members - Calendar
Full Version: what about this?? looks an ideal drainplug
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
dougstar
The question is in the title^^^^^
what do you think anyone using one??
Dougie
Raceface120
I have just put one on mine and it makes changing the oil so much cleaner. (Less ear ache from the missus about oil on the block paving too laugh.gif ).
davie
definetly worth using!
Had one on my last 2 discos and friend has one on his 300tdi disco - great bit of kit
bishbosh
I have heard lots of good reports on this product.
I have also heard of isolated instances where the screw in fitting has sheared off leaving you in a bit of a pickle for changing the oil.
However, I do not have one nor do I have first hand experience of them. It could well be that the failures were operator error / monkey mechanic.
Mark
I have one for my 300TDI disco, and I can't fault it.
The main reason I can't fault it is cos I haven't fitted it yet, but it looks superb! ph34r.gif
probably even less helpful than bish...
Mark
ciderman
There OK but you still end up witha mess all over front diff and prop when you spin the filter off .
Milemarker Type S
Jase - put a plastic bag (not one with holes in it!) over the oil filter when you spin it off- all the oil gets caught in the bag... Saves having it running up your arm as well!
Ivan
Or cut down a 2ltr pop bottle and wrap that around the filter.
HTH
Ivan
Mo Murphy
dougstar,
I've had one on my 300 for several years now and I can't fault it, makes oil changing so much easier and cleaner smile.gif
Mo
dougstar
think the feedback is unanimous on this one so i,m off to place my order now biggrin.gif
Thanks guys
pugwash
QUOTE (bishbosh @ Jun 25 2008, 01:09 PM) *
yeah i was one of those mentioned above
got a bit push happy with a breaker bar and sheared the screw off in the sump
luckily the sump was empty so i drilled out the centre and put the old plug back in until i could get a new drainplug. couldn't recommend them more- make life so so much easier
freeagent
I fitted one of those to my 300Tdi disco after stripping the thread on the original drainplug. rolleyes.gif
we drained the sump then smeared chemical metal onto the damaged threads, re-cut with a tap then glued the diff-lock plug in with loads of loc-tite.... wink.gif
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
