- Make : SIP Weldmate Industrial Synergic
- Model : IC300WS
- How Long have you had it / How old is it : 2 Weeks
- Typical Current Price : £1,200
- Maximum Welding Current (AMPS) : 300
- Output at 60% Duty Cycle : 196
- Welding Wire range in mm :0.6. 0.8, 1.0, 1.2
- Small Large or BOTH re Wire Spools : Yes
- Euro Torch (Yes / No ) : Yes
- Argosheild Bottle - max Size that will fit : Full size
- Weight : 101kg
- What is the most typical things you weld with it - thicknesses etc : 0.8mm - 6mm
- Other standard Features : Synergic functionality
- Good Points : Decent wheels and good construction. 12 Synergic programs for Ferrous, S/Steel, and Ali
- Bad Points : Bluddy huge .......1040 x 1040 x 560
- On a scale of 1 to 10 1 being very unhappy with it, and 10 being "Its perfect for me" rate it :10
OK, so lets look a some pictures ................
Also I have run a few beads ............... however, beads don't photograph particularly well and beads on actual joints always look better but are even harder to photograph.........
let the p!ss taking begin............remember, these are real close ups........... even the splatter looks like mountains
This is 0.8mm (22g) right through to 6mm plate ........... the long plate on the end was done with about 240A just for fun........
Then the real close ups ..............
22g - 0.8mm
18g - 1.2mm (ignore what I wrote on the weld sample - 20g
3mm plate......
6mm plate at about 200A
and lastly 6mm plate welded a 240A ........ christ, you have to move fast
Ian
