QUOTE (noggy @ Jul 4 2008, 01:24 PM)
are staun beadlocks very strong/thick, because what do you do if you get a 6 inch nail through your tyre, does it puncture your beadlock?
do you need to buy a new one or repair?
They are quite robust, the beadlocker is more or less a canvas type case which is held in position with an inner tube. Obviously the inner tube could be patched or replaced, not sure about the locker itself though. Depends how badly it got damaged.
It would have to be a big nail to do such damage unless it went it through the side wall in which case you would probably need to repair the tyre as well.
Its feasable you can punture the tyre yet still drive on the locker, off road of course, not down the M6.
