Ok, before we all get excited, this is for a pre-vapour build early in head project....
I'm thinking about building an external roll cage with a canvas hood hung within it. The aim to produce a dry-ish four seat family vehicle for light offroading with the hood on and then strip the hood and door tops off for competition. Maybe even adding a bolt in diagonal on the cage when the hood is off.
Help I'm after as follows:
Has anybody hung the hood inside the cage before? Is it possible?! Photos!!!!
Any ideas on good hood mounting - how fix to the windscreen top and body nicer than original. Also how to hang inside the cage, for example laced on, or zipped tubes. How to tension the hood inside the cage, with no bars to wrap back on. I've worked on boat canopies with wine-glass rails and bolt rope attachment, anybody used that on a car?
Any tips on neat external cages, I like the style where they mount on the chassis within the body and then appear through the body in the curve below the glass, but is this the best way? I'll probably combine the cage with tubular wings, so this may be best.
