Troddenmasses
Jul 10 2008, 11:04 AM
I have a need to make a loop in the end of a thin piece of steel wire (about 3-4mm diameter) which needs to be secure. I know that people use steel wire for branch protection on their landies, so was wondering how it is normally secured. I know that I can get connectors that you bolt together, but this needs to be thief resistant, and I have seen other steel wires crimped together. Does anybody know how this is done, or where I can have it done?
Cheers,
TM.
headhunter
Jul 10 2008, 12:10 PM
QUOTE (Troddenmasses @ Jul 10 2008, 12:04 PM)
Cheers,
TM.
Go to a rigging company, either one that supplies industrial kit for working aloft or to a marine rigger that supply yachts.
Here's an example with swaged terminals at the bottom of the page -
http://www.southernrigging.co.uk/John
white90
Jul 10 2008, 02:30 PM
Get a Large crimp for welding wire or one large enough to accomodate the wire you want to crimp
get an old pair of pliers, put the crimp in the jaws, find a large hammer and belt the pliers
http://forums.lr4x4.com/index.php?showtopic=4792
jameslwt
Jul 10 2008, 05:26 PM
Depends on what you want to use it for.......proper crimping and swaging as per the stuff used on boats etc is done with a hydraulic press to get a nice tight fit - try www.racing sailboats.co.uk for a good decent mail order service.
Turbocharger
Jul 10 2008, 06:34 PM
Cable clamp and then enclose it in potting compound or epoxy? Or just weld the studs up? In fact, you've got a welder so you could splice / wrap the wire around itself and weld the whole shebang to the inside of a piece of angle iron?
Timpo
Jul 10 2008, 07:13 PM
What about a Bulldog Clamp?
I would be very carefull if you are to use it to support/lift/carry any load.
Timpo.
zimsoundz
Jul 15 2008, 09:12 AM
Can you splice ? If so, this is possible (although a pain) if you are using thin steel cable. There is another way that we kindof undo the cable a bit, and resplice a loop - sorry difficult to explain.
Stick a pair of bulldog clips on just to be sure
This is a bulldog, when fitting, "never saddle a dead horse" :
If you're using it for a purpose that will have some strain on it, then get it done properly. I know at work, we just order in various size slings (from 3mm right up to 75mm in diameter)
G
Troddenmasses
Jul 16 2008, 10:16 AM
Thanks for all the replies - I want it to help me secure a couple of guns into the back of my car. I'm very careful about security, but the consequences if one got stolen don't bear thinking about, so I was looking to sort out a better way of sorting security. I thought that a piece of steel wire crimped around something strong in the back of my car, and then padlocked to the trigger guard would see me right.
Les Brock
Jul 16 2008, 11:52 AM
Is that just not another description of a bike lock ?
Troddenmasses
Jul 16 2008, 04:45 PM
Yes, but it needs to be of a specific length, and made of quite thin steel wire, so that I can use a special gun lock that I have, or if it was really thin, pass the crimped loop down the barrel (I like large calibre stuff) and then lock it.
J@mes
Jul 16 2008, 05:01 PM
something I am also interested in, as I want a way of securing the barrel and action of a shogun to the seatbelt mounting points when I am not in the car.
Was planning to weld mine, unless someone else comes up with something.
A Twig
Jul 19 2008, 04:52 PM
A lockable steel gunbox wouldnt be a safer bet?
J@mes
Jul 19 2008, 05:50 PM
QUOTE (A Twig @ Jul 19 2008, 05:52 PM)
Im not mounting a steel safe in my evo.....
smo
Jul 20 2008, 09:07 AM
QUOTE (J@mes @ Jul 19 2008, 06:50 PM)
Then in reality you shouldn't be carrying firearms in your car!
J@mes
Jul 20 2008, 09:54 AM
QUOTE (smo @ Jul 20 2008, 10:07 AM)
Well, as it happens there is no requirement for me to have extra security fitted to my vehicle. The Home Office is quite happy that the locked boot of a saloon car (ie one without a parcel shelf covering the load space) is a safe enough place to temporarily store shotguns or firearms whilst they are in transit or while the vehicle is unattended for short periods of time. All I wish to do is further increase the safety of carrying guns in the car without adversely effecting the value of the vehicle by drilling the floor to mount a safe.
So, to use a wire rope that is fixed to the seatbelt mounting bolts (which has a large torx head tightened to high torque) will further increase the security of the guns while I am not in the car.
In reality, the Chief Of Police for Lincolnshire has deemed me suitable to possess, carry and use shotguns in accordance with the law, which is what I am doing.
leeds
Jul 20 2008, 11:16 AM
Yellow pages and look for rigging supplies, crane type people in your area.
I want a crimp on a winch cable, went to local crane suppliers and lads in workshop did me a crimp FOC and did not even want some beer money!
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
