The MileMarker is an exellent bit of kit, but let down dreadfully IMHO by the ZF - Slow as a Slow thing System.
However, when thats all said and done it does make the system more affordable to buy than nothing, or a cheap chinese winch-junk option.
To up its speed you'll need
A Hydraulic Fluid Tank
A Spool Valve (a 'lever' for In Neural Out - this has all the pipework in and out of it))
A Over Centre Valve (safety cut off)
1/2 inch BSP Hydraulic braided hoses (the MM stuff is too restrictive)
A PTO Pump ( I use a Superwinch H14W Pump and Tank)
Proper Hydraulic Oil (EP32 in my case)
A System Filter
A High Pressure Motor (the std one on the MM blows up if you give it all of the above - ask me <cough> how I know
I have a rear MM.... PTO from H14W Tank from the same H14W system which has a built in filter)
...spoolblock from Steerforth (twin unit controls front and rear winches off the same system) 1/2 Hosework and it gives me about 75 ft a minute in 4th gear at about 2000 RPM
Have a read also of ian (Bull Bar Cowboys) write up on a fast hydro unit
HTH
Nige
