Help - Search - Members - Calendar
Full Version: 44/42 inch tyres but what axles!
LR4x4 - The Land Rover Forum > The Lounge > Tools and Fabrication
Pages: 1, 2
russ1
Afternoon
Am sitting in the sun and thort i would spec up my new build for my challange truck
I want to run 42 or 44 inch tyres but the problem is i am unsure about axles really dont know what to go for.
Volvo c303 = hard to come by, would they stand up to hard use with 44s?
Spidiertrax axles = When looking at then at billing there had a price up for a landy set up starting at 10K.
Rockwells = Hard to get in uk, no lockers etc.
Would need lockers, and spare parts etc, Disc brakes would be nice but could get around that.
Can any one think of any others, or could throw any info on the above.
Not to fussed if i used portals or normal axles.
Thanks again
pugwash
Mog 404 axles will certainly stand up to that abuse of 44" tyres.
dollythelw
and yep, Volvos will stand that if they're set up.
dana 60s could be worth a wheeze - a mate picked a set up from holland for €300 a couple of months ago
or ship in a pair of axles from the US?
6cyltdi
Rockwells from a renault trm 2000 are easy enough to pick up here.... rear has a locker....
I'm fitting simca's at present to my series and they should have no problem with that tyre size..
There are good spares availability for either axle and they won't break the bank.....
Or toy 80 series axles???
Loads of possibilities depends on what you want/ will be using it for and what you can afford
pugwash
QUOTE (6cyltdi @ Jul 27 2008, 08:03 PM) *
turning into a bit of an ardent 80 series fan here- BUT i have to be honest and say that i wouldn't run 44s through 80 axles- i reckon that's the upper limit of what they would take before being able to guarantee against failure.
My longfield CVs have a recommendation not to use above 44" and a locked axle- it doesn't void the warranty though but bobby longfield reckons your starting to take a risk with that size of CV. Having said that guys in the states run rock crawlers with Toy axles and 44s so they can't be hideously unreliable.
personally for that sort of size i would look at something a lot beefier than anything originally conceived for a light truck (and yes a landcruiser is still a light truck before i get abuse!)- 303, Mog, rockwell or similar would have to be my choice. Good thing about these is that the portals take care of gearing so you don't have to worry about ring and pinion changes which has to be a benefit.
russ1
Thanks for the replys people, never had much to do with toy axles or danas so wouldnt really know where to start with them,
Jez;
When you say 303s will be ok if set up could you go into that abit more? Thanks
Mog 404s = am i right in saying that they are very heavy? Saying that 44s arent goint to be light!!
Thanks again
Hendrik
we had the same question a year ago...
all axles have their own benefits and downsides, but at the end we went for Spidertrax axles because of weight, they've been abused and prooved well in US competitions, they're specially built for offroad use, etc etc.
Good luck with your choice!
H.
dollythelw
depending on what you want to spin width wise and how many ponies and ft/lbs.. fresh bearings, correctly built diff, properly set diff lock actuator. if you go for volvos ping me and I'll nose you through it all - we must be doing something right, our stuff keeps holding together unsure.gif
how wide a tyre do you wanna fling and how many ponies?
carl hurst
Dans 60's are a good base, 35 spline internals will stand upto 44's ford 9" high pinions are strong,
Spidertrax use these bits in a custom case but big coin,
Dana fronts are rare in uk so you may need to import and you need to look at what truck it came from as the choice of dana's is large as they are on fords,chevys,dodge etc and all slightly differant,
I'me building a set for my truck that will run 44"s and have just about got it sused out,even building my own casings and and machining the bits it still is'nt cheep but they will be bomb prof,
Carl.
callum
QUOTE (pugwash @ Jul 27 2008, 08:25 PM) *
longfield don't seem to recommend over 39" for their stuff. the 80 series front would object to such large tyres, its only an 8" mini truck diff and reverse cut. reversing out of a hole, it would probably ping like a rover diff. the back is 9.5" (i think, or thereabouts) so is a bit stronger. best bet from the toyota stable is the 60 series i think, full sized diffs front and rear and cable lockers if you get the right ones. smaller cv's than an 80, but the 80 cv's are much stronger than the diff into which they connect so they are of little advantage.
carl hurst
Another point to consider is the gearing,you will need to look at your ratios in trans box and ring and pinions and if you go portal with 44's then your truck will be very tall to the point that it will want to flip end over when you go down hill,
Carl.
russ1
QUOTE (dollythelw @ Jul 27 2008, 09:23 PM) *
Portals have there plus points!
Tyre wise would be heading the bogger route, 44s work out to 19.5 couldnt find any 42s in a 16.5 rim but 39.5 ( could be another choice ) work out to 18.
Power wise iwould be going for a tuned rover v8.
You havnt got any 303s flooting about that you dont want do you? rolleyes.gif rolleyes.gif
dollythelw
ping me your email addy and I'll send you some links - theres a few places about saying they have stock smile.gif
pugwash
QUOTE (callum @ Jul 27 2008, 10:08 PM) *
Well the blurb with the longfield CVs for the FJ80 superset (including strengthened halfshafts) said "we dont' recommend welded spool with over 42" tyres". When i phoned and spoke to bobby longfield i was told that he was happy for the CVs to run up to 44" and warrantied that against breakages.
Dont forget that they are hypoid diffs so that little bit stronger- guys in the states are crawling with them with 42" tyres and dont pop diffs so they've got to be quite strong. I'm certainly not aware of any diff issues on 80 series axles on either ih8mud or pirate.
Of course one benefit is that you can re-gear the axles very cheaply and easily on the 80 stuff so reducing some of the strain on the diff.
Unfortunately my 80 doesn't have huge tyres- they are only 33" MTs, but i wouldn't hesitate to run up to 38" even with my lardy arsed truck.
dirtydiesel
Volvo's are a little girly for 44's but they are light.
Rockwells, bloody heavy and would cost a fortune in disc brakes and lockers, and most of the ones you'll find in the uk have the smaler weak shafts in them.
Dana 60's, you'll need the 44's to get some ground clearance back, can be built really tough but spendy.
Toys, don't stand a chance.
Nissans, much the same as toy's but they might live a little longer.
Mog 404's, 44's are just about within there limits, spendy on disc and pinion conversions. heavy but not that bad.
Full fat mogs, will laugh at 44's, most come factory disked, spendy pinion conversions on these and weigh nearly as much as the rockwells.
Cost, weight, strength. pick any two.
dirtydiesel
QUOTE (carl hurst @ Jul 27 2008, 10:28 PM) *
Carl.
And you know this how?
sheeppimp
QUOTE (dirtydiesel @ Jul 28 2008, 12:32 AM) *
everyone knows portals make trucks fall over and small kittens explode tongue.gif laugh.gif
carl hurst
Ask alan kemp about being unstable,Dan, your truck is not to tall so may compensate,
A Dana 60 diff is the same size as a sailsbury so chop it out and use the ford 9" high pinions to get the clearance back, still uses D60 internals without the bulk,
Carl.
pugwash
QUOTE (carl hurst @ Jul 28 2008, 09:28 AM) *
Carl.
My vapour build, based on a range rover, has a roofline 2" higher than other challenge prepped rangies- and most of that is due to tyre size.
Of course the good thing about mog axles is that they reduce your centre of gravity so making the truck more stable.
dollythelw
Im only on 40's but never found stability to be an issue - bear in mind Carl a 44x19 Bogger is a heavy old bit of rubber to fling (65kgs plus wheel)
carl hurst
QUOTE (pugwash @ Jul 28 2008, 09:49 AM) *
Yes if you get everyting else spot on as in engine position,lengh of wheel base suspension etc, it will be stable but my point was that going down hill the centre of gravity shifts and the front axle becomes a fulcrum an gets scary,not saying portals are no good just that the set up is very important,more than a normal beam axle set up,
Carl
Hendrik
QUOTE (dollythelw @ Jul 28 2008, 10:20 AM) *
indeed F*ckin heavy... we have done the test and it was 87kgs for a 44" bogger with steel beadlock wheel (MRW).
dollythelw
the nice thing though Hendrik as you know they stick to the ground like a magnet - not so good when you try to fit them to the car on your own without a shovel to help though laugh.gif
FridgeFreezer
Carl.
carl hurst
QUOTE (FridgeFreezer @ Jul 28 2008, 12:02 PM) *
unsure.gif unsure.gif ?
Carl.
bishbosh
QUOTE (carl hurst @ Jul 27 2008, 09:30 PM) *
carl hurst
QUOTE (bishbosh @ Jul 28 2008, 12:36 PM) *
Now the owner of a pair of dana's,
Carl.
alan kemp
My truck used to be unstable when it was on +2" springs and a 3 link. I now run on -2" springs and disco II. It is very stable if a little wider than with Volvo wheels on. I will take on any side slope a standard LR will do. End over end is easier on my axles, if you drop off something very steep, the centre of gravity can make you stand on the front wheels. As long as you are aware of what to do, its not a problem. My truck is a bit longer now which helps.
Depending on your money available, go with Portal-tek, they have an offer on at the moment linky
russ1
QUOTE (carl hurst @ Jul 28 2008, 12:58 PM) *
Carl.
Doh, missed that one!
carl hurst
QUOTE (russ1 @ Jul 28 2008, 02:45 PM) *
I only need one, maybe a deal on the other?
Carl.
russ1
QUOTE (dollythelw @ Jul 28 2008, 12:17 AM) *
PM sent mate
Ced
It was my Landy at Billing withe the Spidertrax 9 bolt on kit.
It's a nice kit, very strong and very reliable !
plasticbadger
I see lots of Aussies run the 80 series LC rear (which when I measured mine I made 10 1/4" on the Ring?) and the Nissan Patrol GU front. They use this setup with 300+ hp and 42s certainly, but with plenty of uprated internals.
I haven't broken anything on LC axles yet, and I'm running 37" in reverse up rocks with the locker in.
My LC alxes cost £125 for the pair and my brother's Unimog 404 axles cost £300 for the pair with wheels and tyres. He's made the pinion conversion, high steer arms himself and is keep the drum brakes.
dirtydiesel
Carl.
Tyre size and axles choice have very little to do with unstability, weight distribution and cog are far more important.
You've been missinformed about the uinterchangeability of dana 60 and ford 9 inch parts, they are about as different as chalk and cheese.
The only possible similarity is that aftermarket shafts and diff centers are available to run 1.5 inch 35 spline dana 60 1 ton shafts in the ford 9 inch.
henk
Spidertrax in combination with Portals
russ1
QUOTE (henk @ Jul 29 2008, 01:40 PM) *
They looked good but after looking at the std ones with a price starting at 10k +vat i didnt dare ask about them.
Little bit out my price range!
Pugwash;
Replyed to your pm.
Jez;
Did you get a chance to sort them links out for the 303s?
Thanks
carl hurst
QUOTE (dirtydiesel @ Jul 29 2008, 09:59 AM) *
Missinformed???????????? Aftermarket shafts will obviously be needed if shortning to fit a L/R ARB Lockers 1.5" 35 spline are available,
IF not then why do spidertrax run ford type H/P, Already looked into this, I am building coustom axles with all this stuff in them,
Carl.
dollythelw
Russ - soz not yet, just bought my mate out from hospital so will get it sorted tonight sad.gif
carl hurst
QUOTE (dollythelw @ Jul 29 2008, 02:04 PM) *
Jez,
Prety shure the drop box's in the pic are mog's, portal tek seem to have there name allover there drop box's like alans ones but they still use spider trax tubes,
Carl.
dirtydiesel
QUOTE (carl hurst @ Jul 29 2008, 01:56 PM) *
Carl.
dana 60's have a 10.5 inch ring gear, and crucially are available in a reverse cut pattern, which is an essential in the front axle of a high horsepower big tyre'd straight axled truck.
where as the ford 9 inch (to the best of my knowledge) has no reverse cut gear sets for it and due to the odd pinion bearing design the diff centers are considerably weaker.
It is worth while noting that in it's original use the 9inch is a light-medium duty axle. the 60 is a medium-heavy duty axle.
Why would you want to narrow the axles down to L/R width?
QUOTE (carl hurst @ Jul 29 2008, 02:11 PM) *
Jez,
Carl.
The one in the pic is a 404 mog portal box.
carl hurst
Dan ,don't want this to turn into a argument,
The ford 9 high and low pinion diffs when modified with lockers and strong ring and pinions (the pinion has a greater bearing surface on crown wheel) with after market shafts is very strong,
A ford 9" is from a ford F350 1 ton 4x4 truck so should be available in stock 35 spilne iners and 30 spline outer which can be changed to 35 spline quite easy, The dana 60 diff is larger and ultimatly stronger but the ford 9 will cope with 44"s easyly, the yanks have been using them for long time, we are miles behind them on this stuff,
Spidertrax and portal-tek use 9" high pinion's so they must think they are ok, The amount of after market stuff for dana's is massive and it's tried and tested on bigger truck's with lots of hp than we use in uk,
http://www.pirate4x4.com/tech/billavista/60_front/ This link to pirate 4x4 has lots of answers it's worth reading if you want to findout about dana's,
Carl.
Hendrik
QUOTE (dirtydiesel @ Jul 29 2008, 06:36 PM) *
correct!
H.
dollythelw
Carl - Im pretty well up with Portal Tek stuff laugh.gif , the post was a friendly wink at Hendrik and Dieter - spidertrax housings are pretty much an industry standard for new build tough axles, Rob (Portal Tek) uses them with his portals (they are an investment cast, immensely strong design - hence the branding) and Dieters version will be a mog derivative, dont worry, I can tell the difference wink.gif
Mog 9's arent new, in fact Hummer 9's, Uaz Rovers, Praga mutants, UaZ/self build chain and pretty much everything in between has been tried - just with varying success and engineering talent
its great to see new toys though - and if it makes good stuff more accessible then long may it be smile.gif
dirtydiesel
QUOTE (carl hurst @ Jul 29 2008, 09:50 PM) *
Who's arguing?
Carl.
Ford never put the 9 inch in the back of a f350, for the most part they run a dana 60 in the front and a sterling 10.5 inch in the back.
Think about it why would ford be running a 9 inch in the back when there competitors run much much bigger axles in the front?
carl hurst
QUOTE (dirtydiesel @ Jul 30 2008, 11:51 PM) *
Who's arguing?
Who said they did?
Dont realy care who put what in where,
we are talking about coustom built axels not factory fitted stuff so we can mix and match whatever, Its called INOVATION,
Carl.
muddy
QUOTE
INOVATION
Rizla 1
[quote name='russ1' date='Jul 29 2008, 01:51 PM' post='293061'
Thanks
[/quote]
I been trying volvo portals on my 80" trials truck and found that they make it far to unstable - the same as Alan K said.
It was a nightmare to drive in Norway last weekend on the rocks - So my fully rebuilt c306 portals with cromoly CV's and shafts , disc brakes and air difflocks will be on the market in a short while - I'm going salisbury
These axle in my apinion are good for challenge but not so good for trials unless your truck is maybe 110" wheelbase
FridgeFreezer
QUOTE (Rizla 1 @ Jul 31 2008, 10:15 AM) *
alan kemp
Get some of these and be done with it.
Click to view attachment
Can I just confirm, my car is not unstable, it is a myth borne out of rolling lots when I knew nothing..................... So there tongue.gif
carl hurst
QUOTE (alan kemp @ Jul 31 2008, 07:34 PM) *
Alan 'roly poly' kemp, them axles are sexy, i think some people will be loving themself's over them,
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2008 Invision Power Services, Inc.
