Well i finally got around to fitting the patrol axles to the Disco trayback after having them sit around for 12 months while I got my motivation together. Breaking a 3rd Rover diff in 4 outings was the final straw.
Click to view attachment
One of the main reasons I made the change. Plus the fact that they come as 4.11 ratio and have a rear locker as standard.
Front alxe is straightforward. Cut off nissan spring mounts and weld on LR ones.
Fabricate a new panhard rod by cutting the 2 and welding them together at correct length. Luckily the LR one is solid and fits (very) tightly inside the Nissan one which is hollow.
Simply use the Nissan radius arms in the LR chassis mounts and its on.
The TRE on the rover drag link fits the steering arm OK but the drag link is about 5 cms too short. Initially I wound out the 2 ends but then discovered that since my steering box has the swan-neck droparm like a defender the drag link is in fact 5 cms shorter that that fitted to later discos. A quick visit to town and a new drag link and its all OK now.
Other things you need to do on the front are put a run of weld into the pinion flange recess and then turn it down to accept the LR propshaft end. You can then drill 4 new holes. The front prop also need shortening by about 2-3 cms which can be down easily enough if you've got this far.
Slit the prop just shy of the weld and knock the end off... it is a tight push fit.
Then use a chopsaw or similar to remove however much you need to from the prop tube, then knock the end back on and reweld the thing back together. Don't forget to mark the position of the yoke before you cut it off.
All that remains is to connect the brakes but this is pretty straightforward as they are 10mm metric fine on both vehicles
Onto the rear. This is pretty easy too but a pain due to central diff. If I had taken more note at the outset I think I may have cut the axle tube and shortened one side by 5 cm and lengthened the other by the same amount. This is because although the diff pinion is dead central the diff is offset to the passenger side. This means that there is a long and a short halfshaft. As far as I could see there would be no reason that they could not be swapped over if the tube was cut and shut and that would bring the pinion flange much more into line with the transfer box thus reducing problems of propshaft vibration and alignment. Heres a pic from below to show how much angle there is. OK on 100" but would be a problem on a 90
Note my helper!
To fit the axle I simply debracketed it and made up/transferred across the bracketry from the LR axle.
Tricky bit was the ball joint bracket but a bit of HD fabrication and she was OK.
I did end up cutting and sutting a recess into the top of the casing before I welded the ball joint bracket on so as to enable the use of a ring spanner on the bolt. I could have made the bracket taller but this would have made it weaker and would have adverse affects on the already altered geometry.
The rear pinion flange simply needed turning down a fraction to get the LR prop to fit and the new holes drilling. Rear prop also need shortening by 2-3 cms
Brakes were not a problem, just a new hose and new pipes on axle.
The rear locker works on a vacuum and has a switch to operate a warning light in it. The switch was wired in and pipes run forward to the engine bay. There I sourced an electric 2 way vacuum solenoid thingy from a subaru Justy I had under the hedge. this is used to operated the 4WD on the Subaru by the same method as the Nissan difflock. Wired it all to a switch and warning light and T'd into the servo pipe to get the vacuum and it works just fine.
Taken here out for a few tests now. Am very happy with it. Some vibration at road speeds but she is not destined to spend any time there so not too bothered by that. Happy to have my gearing back too.
Anyway sorry this is long winded. Hopefully of help to someone out there. Any questions feel free to ask
Mark
