I'm looking at getting some custom made progressive rate springs for the rear of my RRC, mainly to restrict upwards tyre movement (blasted inner wheel arches), whilst maintaining a softish suspension and doing away with dislocating springs whilst I'm at it. I've measured and weighted up the RRC so I got a number of the basic requirements worked out, but I have a few questions.
1) I have static weights acting on the springs, are there any rules thumb for predicting the dynamic laods, both with the axle level, ie. driving over a speed bump and when on articulation, ie. driving quickly through a set of axle twisters?
2) Are there any companies that you would recomend for custom wound springs?
3) Has anyone used bump stops inside the coil springs on a LR, if so how succesful were they?
If I just extended the normal bump stops far enough to stop the tyre hitting the wheel arch on full articulation then there would only be an inch or so clearance between the axle and bumpstop when parked on level ground. I could lift the suspension more to get round this problem, but for various reasons I don't what to lift it much more than it already is.
Using double spring is another option, though the approximate costs I've gathered so far for custom wounds for a LR are no more expevise than a pair of uprated springs of a suitable rate/length and some X-springs.
