Help - Search - Members - Calendar
Full Version: Leaking Roof.
LR4x4 - The Land Rover Forum > Vehicles > Series Forum
kingdong2
Hi guys
went out in the landy today to get a new washing machine reversed out of the drive and then stoped to go forwards and i got coverd in water i was well soaked i am a bit hacked off because last year i fully sealed the roof inside and out and the roof didn't leak in but now it is i now a p.o. must of carried something on the roof at some point as the front of the roof is slightly bellowed so i am thinking of getting another roof but fancy one with alpine windows.
graham.
yellow
As you did it yourself, I'd say the roof is still sealed. It might have been a build up of condensation on the inside of the roof.
I had a steady drip from the roof, especially the sunroof as the condensation on the inside started melting and dripping on my pants (Granted this is a 110, but the roof is the same)
kingdong2
QUOTE (yellow @ Oct 28 2008, 01:57 PM) *
nop the inside of the roof was dry as it normaly has been i found the leak it is leaking from the seam that goes across over the steering wheel as thoe to speak.
graham.
sotal
I found mine used to get condensation when the weather changed, if parked on a hill it ran to one end and gathered in the sort of gutter bit inside. Then when I get in a few days later the roof would look dry, but when I set off all the water would run to the front and shower me.
If you are sure it's not condensation then get someone to spray it with a hose whilst you sit inside watching for leaks
kingdong2
think it mite have been the green laning i did the other week branches may have broken the seal ?
graham.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
