Help - Search - Members - Calendar
Full Version: hellp needed with vacuum diff
LR4x4 - The Land Rover Forum > Vehicles > Range Rover Forum
bobtail 26
hi to all my vacuum diff is not working i think a pipe has come off but is there anyway i can lock the diff in so i dont have to use the vacuum and the lock is in all the time
sheltie50
Better to fix the problem and not put too much strain on the tranny
bobtail 26
QUOTE (sheltie50 @ Nov 1 2008, 02:11 AM) *
ok thanks mate
bmhor
You can remove the vacuum module and replace with a lever to give YOU control of when diff lock is in or out...
If you just need to dissengage the diff, you can put air pressure to the opposite side which will work.
I suppose that if you had an onboard compressor, you could do away with the vacuum pipe and run it only of compressed air using the same switch.
If you want more info on the manual conversion, let me know and I'll dig out the photo's from the last time I did the conversion.
Bob
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
