QUOTE (stumonkey17 @ Nov 13 2008, 12:39 AM)
I'm in the process of rebuilding my 88" series 3 and need to re-wire the whole vehicle. Can't really afford a whole new loom from the likes of Autosparks and want to do the job myself encorporating an EDIS system and mega jolt. I realise that this is a big job but still want to give it a go as once completed I'll be able to modify or repair relatively easily. Should also mean that i can make the electrics relatively waterproof to take advantage of the EDIS. The engine is a 2.25 petrol. I know that whilst I'm planning the wiring system I need to calculate what cable to use. I know that i can culculate the ampage of wire required but need to know the watts consumed by the equipment to be supplied. How can i work this out so that I can work out what wire to use? Any help would be really appreciated.
Hi,
I rewired my Lightweight using the remains of one two Range Rover harness! They came with a nice blade fuse box also.
There was enough fuseholders for all normal stuff along with acc such as fan/spots etc.
If rewiring i would suggest a set of relays. For headlights dip/full, electric fan, horn to name a few!
Buy some holders that can interlink and will make it nice and tidy. You can get the connectors to go with them to customise your install.
The only problem with the RR fusebox is no available connectors are readily available.. that i know of. unlike that from Vehicle wiring products that use standard lucar crimps. I was able to remove the connectors from the fuse holder though and used a combination from a few harnesses. (Try get fuse/fusebox as close to battery as possible).
The beauty with the RR harnes is that it had correct colour codes and weight/amperage that i was looking for.
Get yourself a nice mulitmeter and a quality crimp tool. Worth the investment if you going down this road!
You will need to check any used wiring before putting in cct though. Steer clear of wires that are black copper or stiff.
Oh i also used recycled sleeving to fit cables in. DONT wrap cables in insulating tape! Good idea i know, nice and tidy today but nasty and sticky next week.
If you need some more help give me a shout.
