Help - Search - Members - Calendar
Full Version: V8 LT77- No reverse?
LR4x4 - The Land Rover Forum > Vehicles > Defender Forum
Quagmire
Right, so the story is like this.
Got home last night from work, parked as per usual no problem.
Got out to the car this morning to find i had (unusually for me) left it in gear- reverse actually.
Whacked it into neutral and started up, moved forward and then went to select reverse. No reverse... blink.gif
Tried again and again, its like there isn't even a reverse gate anymore.
Any suggestions on what to look at? Its sitting outside the office at the mo having been pushed backwards into a space. Unluckily for me the car park is dead flat so no option of parking nose in and then rolling out...
Anyone got any ideas for what i should look at? I'm hoping its just some kind of selector fault. I know nothing about gearboxes...
Quagmire
Ok have just done some searching, and seems that the reverse light switch may stop me getting through the gate. I know what i'll be doing at lunchtime...
Any ideas if that isnt it?
Thanks!
Hamish Grundy
QUOTE (Quagmire @ Nov 14 2008, 07:51 AM) *
Thanks!
hi, ive got exactly the same problem, i if i slam it across it goes but it cant be doing it much good, let me know if it is the reverse switch and il have a check on mine. i just assumed it was the stick getting stiff, my box has been sat in the workshop since 1989!! just thought it needed a bit of freeing off!! ha
cheers
hamish
MuddyWinny
I had something similar on my LT77 (2.25 petrol though).
Basically the knuckle(?) at the base of the gear level was covered in mud. Once it was cleaned and lubricated getting over the gate and into reverse was fine.
Quagmire
Just went out and checked it.
The end of the reverse switch is smashed, and i'm assuming that the rest of it is in the selector mech somewhere stopping me getting through the gate somehow. I never checked the switch was setup correctly when i changed the box, and it must have been wound too far in. dry.gif
western
take the rubber boot of, gear lever turret & bias spring off & you should be able to retrieve any unwanted remains of the reverse switch.
Quagmire
QUOTE (western @ Nov 14 2008, 01:34 PM) *
Hamish Grundy
damn, i guess thats what was stopping mine, i bet ive smahsed mine too, i wonder if my reversing light still works....
Hamish Grundy
QUOTE (Quagmire @ Nov 14 2008, 01:14 PM) *
my switch is fine....and its engaging fine at the moment..(touching wood)....might just want a clean out!
Quagmire
QUOTE (Hamish Grundy @ Nov 16 2008, 11:26 PM) *
Had more of a look at the problem last night and although the switch was broken (and no doubt the bits are now somewhere in the box) the actual problem was that the reverse plunger was seized. Totally and utterly. Was full of water and the ball bearing was pretty shot. Luckily i had an identical plunger unit on a spare box i have...
Hamish Grundy
QUOTE (Quagmire @ Nov 18 2008, 07:42 AM) *
Had more of a look at the problem last night and although the switch was broken (and no doubt the bits are no somewhere in the box) the actual problem was that the reverse plunger was seized. Totally and utterly. Was full of water and the ball bearing was pretty shot. Luckily i had an identical plunger unit on a spare box i have...
ah right...so i should realy have it appart and check it. another job for the weekend!! thanks for the info!!
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
