Help - Search - Members - Calendar
Full Version: HDC problem ?
LR4x4 - The Land Rover Forum > Vehicles > Freelander Forum
win32
I got small (i think tongue.gif ) problem with my '00 Freelander. My HDC system work quite strange :
When i put starter swich to position II , HDC lights (green & abmber) lights up , and out in a few seconds - this is OK, BUT : , when I select HDC on my gear lever , green light won't illuminate , won't flash... i select first & rev gear , the light is still dark.
I read LR manual , and that light should be flash if ony other gear is selected , and iluminate when i select HDC...
I think that HDC System is working good, when i drive down from small hill , HDC has breaking my Freelander very nice...
Add Info :
'00 5 Door Freelander , with manual Gearbox , 2.0 Diesel L-Series
Thank you.
P.S
win32
Hi,
(yes i know double post wink.gif ) ,
I found some clues for my HDC problem. Today I remove gear lever gaiter, and I found multiconnector with two wires (purple & Black) smile.gif . Every thing should be fine but , i can't find any - ANY blink.gif place to plug it in huh.gif . I look around precisely my gear lever & HDC Switch... no connector...
How should be look that connector , and where it is localized on gear lever ? I found some broken plastic near the lever, so i think that former owner of my Landy broke down unsure.gif ph34r.gif the plug connector.
so , Probably i need new HDC switch , i found two part numbers , but no photos of parts. Witch part number from those two is correct for my car ?
#1 UMB100080
or
#2 UML100000LNF
Greets
v8bertha
Hi,
According to Microcat, UML100000LNF is the switch that goes on the gearstick. The other switch goes in the gearbox.
Hope this helps!
Dan
win32
Thank you for information & image smile.gif . It realy help me... now i can order correct parts.
Greets
Lukas
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
