Help - Search - Members - Calendar
Full Version: How much lift do I need?
LR4x4 - The Land Rover Forum > Vehicles > Discovery Forum
Brookers
I'm looking at going up to a set of 37" creepy's on my disco 1 but i'm unsure how much lift I will need to give enough room to let the front end articulate properly. I'm going to fit a set of extended arches to make room for them. I know that I need more than 2" of lift but how much more? 3", 4"?
At the moment I'm thinking that 4" of lift should be enough, am I right? if so how should I go about it? 4" on the suspension with a combination of spacers and 2" lift kit? Im aware of the work needed with props, castor angle panhard rod etc.
Also what mods can I do to the inner arches to improve things?
Thoughts and comments please
Cheers Brookers
discojmz
i wouldnt have thought that 4 inches lift alone would be sufficient if you want it to articulate 'properly'. no direct experience of this myself, but your main problem will be any amount of up travel. regardless of the arches being cut and flared, I dont think the inner arches themselves are big enough on the inside to accommodate 37s... If its only downtravel you crave, then you'd probably be fine but imo its only half the picture. id be only too happy to be corrected though!
Fern
A fellow of mine has 35x14.5 with 2" suspension lift + 2" body lift + cutted arches.
I think that with 37" you will have cut the arches more 1" on each side to make them wider. (37-35)/2=1"
Brookers
Hmmmm maybe I should re think and look at 35's
Thanks for the imput
Brookers
Young bobtail Rhys
I have 35/11.5 simex on my rrc with 70mm on spring lift and extended arches. They work fine, no major probs. With 37" tyres you would need a 4" lift, 2 on the body and 2 on the springs. However, the centre of gravity would be very high making it unstable and the tyres would still probably catch on the front inner arch footwell. Steering lock would be seriously limited as well. I personally would recommed 35's as they are a good all round size to fit which can be done pretty easily and cost effective.
discomikey
you dont need to lift it in my view
it just makes it harder to get over bumps etc
which makes you as a driver more skilled wink.gif the camel trophy ones were never lifted and they got everywhere they tried
if you want one have a 2" lift as any more can make the steering go wrong unless you get the relevant radius arms which costs upwards of £200
mikey
AndyEvans
u will also prob want to put a 1.4 transfer box in instead beacuse it might be rather too high geared otherwise
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
