Help - Search - Members - Calendar
Full Version: lift another inch
LR4x4 - The Land Rover Forum > Vehicles > Discovery Forum
yogibear47.lee
hi i want to lift it another inch to 3" i have a 2" lift kit on (springs and shocks) with some 265/75/16 and i think it need another inch which way can i do it, what else would i have to do with it.
im getting some plus 2" extended brake lines, will i have to lower the rear shock mount and get a lower front turret
hope you can help
Bowie69
Why do you think you need another inch, out of curiosity?
Going another inch can give all sorts of geometry problems and propshaft issues... normally 2" is enough for most people...
Young bobtail Rhys
With a 2" lift, the 265/75 tyres will be fine, with extended arches you could run 34" tyres (possibly 35") but with a 3" lift you could run a true 35" tyre no problem if you had extended arches (as this is what I have) so really there is no reason why you would need to lift it up another inch as really you want to keep the car's centre of gravity as low as possible.
HTH
yogibear47.lee
its got extended arches, just dont think it look right to be honest
look alright there
dont look right on the front
it might be me it has a 2" pro comp lift kit
6cyltdi
QUOTE (yogibear47.lee @ Nov 17 2008, 12:36 AM) *
look alright there
I'd say it looks fine... Is there a pic like the top one but of the drivers side..? Back wheel looks a little far forward? unsure.gif
Bowie69
Hmm, only thing I would say is that with better offset wheels it would make the arches more worthwhile, and your potential steering lock would improve...
timmymac
QUOTE (Young bobtail Rhys @ Nov 16 2008, 01:20 PM) *
HTH
#this maybe a silly question but how would an extra inch make that much difference to the 35" tyre as the bump stop remains in the same place so on hard articulation you will have the same problems as a 2" lift.
only asking because i have 35" tyres, 2" lift and want to if im losing out somewhere
cheers
Young bobtail Rhys
Yep a 2" lift also works fine. I have extended bump stops, +70mm springs and the gwyn lewis challenge setup. My bump stops never get hit unless the wheels travel vertically up, i.e it bottoms out. What this means is that my extended bump stop is now too short as it was designed for a 2" lift and is therefore 1" too short. The travel is still the same, but is an inch higher to start with and therefore when the wheel is at the top of its articulation, it is an inch lower than on a 2" lift. The correct solution is a 2" lift and a 1" body lift. This way it is only the body going up higher and keeps a little more weight lower down, which means the car's centre of gravity is lower. That is if you need a 3" lift for your tyres.
Some 35" tyres are actually bigger than others. I ran 35" mickey thompsons that measured around 34.5" tall and I am now running simex that are 35 1/4" tall. The tyres width also plays a big part in how high the car needs to be raised etc.
Milemarker Type S
Looks fine to me and as long as the tyres are not hitting the bodywork etc then I would steer clear of any further lift... The higher you go the higher your COG and with it a reduction in the side slope angle you can safely drive without tipping over.
timmymac
QUOTE (Young bobtail Rhys @ Nov 17 2008, 07:22 PM) *
ok cheers as i say i have 35s ,2" lift but forgot to mention 1 1/2" body lift so should be covered, havent used the car much yet so dont no exactly how it behaves. thanks for the info
also i think the disco looks fine. if it works ok and its only looks your basing the extra inch on i wouldnt worry
yogibear47.lee
QUOTE
I\'d say it looks fine... Is there a pic like the top one but of the drivers side..? Back wheel looks a little far forward? unsure.gif
no mate i havent, i thought that but its the flare arches what make it look like that here the pic off my old landy with out any, about half off the lenght of the arch has been cut
[/URL][/img]
i know its not the same side but you can tell by the pic
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
