QUOTE (Escape @ Nov 18 2008, 01:01 PM)
I must admit the BMW isn't bad for cruising at high speeds (the DT will easily do 100mph), but it appears less lively on low revs than a Tdi. Which in my book makes it a poor choice for an offroader on large tyres.
Yes the figures do seem to favour the TDi lower down the rev range with the maximum torque being available earlier.
2.5 DSE
MAXIMUM POWER OUTPUT: 134 bhp (100 kW) @ 4400 rpm
MAXIMUM TORQUE: 199 lb ft (270 N.m) @ 2300 rpm
200 Tdi (Couldn't find the 300's spec but its fairly close I'd imagine)
111bhp @4000rpm, 195 lb-ft @1,800 rpm
If the BMW 2.5 is happier to cruise at higher rev's you would get away with changing the transfer box to the defender 1.4 or even the 1.67 wouldn't you?
The 200 & 300 tdi's are quite flat higher up the rev range. I don't think they would be happy at 100mph.
100mph on 35" mud tyres is around 25mph over their speed rating & wouldn't be safe.
I'm not a big fan of either engine & not an expert. But in my opinion the BMW 2.5 is the better of the 2 engines, only marginally though, & I doubt it'll be worth the extra hassle in standard form.
The TDi's are simple to maintain & easy to fit. Just lacking in power in my opinion, but I prefer larger diesels & v8's.
The isuzu diesel has been the only small diesel engine I have been reasonably impressed with, I find the 200/300tdi's just are a little slow on road.
The TD5's & other modern diesels are great but expensive & complex to fit into a classic range rover.
If you can do most of the work yourself its still worth going ahead & fitting the BMW diesel. It should be nicer to drive with a BMW engine, I imagine the perkins is great off road but really slow on road, it doesn't rev very freely does it?
